Reaplacing clutch.... smoking battery wires
Old 08-30-2005, 04:14 AM
0x5359-0055
213374U's Avatar
Default Reaplacing clutch.... smoking battery wires
95 Acura Integra LS 1.8
I was replacing my clutch and flywheel. When i was pretty much done i tried to hook my battery back up and the wires started to smoke. i tried to disconnect them asap but before i could the post clamp had melted the positive teminal a little. I'm assuming i mixed a ground with a hot wire some where but where?
What would cause this to happen? Any pictures from factory manual would help.
Old 08-30-2005, 04:24 AM
projectac's Avatar
Default Re: Reaplacing clutch.... smoking battery wires (Vt4cPwn35)
check all yours wires make sure they are all correct, check the starter wires and all grounds..and make sure u didn t burn any fuse...
Old 08-30-2005, 05:45 AM
0x5359-0055
213374U's Avatar
Default Re: Reaplacing clutch.... smoking battery wires (projectac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectac &raquo;</TD></TR><TR><TD CLASS="quote">check all yours wires make sure they are all correct, check the starter wires and all grounds..and make sure u didn t burn any fuse...</TD></TR></TABLE>
This is obvious...... Need factory manual pics to help
Old 08-30-2005, 06:08 AM
HogWild's Avatar
Make sure a ground isn't touching a hot wire and make sure your terminals are clamped correctly.
Old 08-30-2005, 07:03 AM
Sam92Teg's Avatar
Default Re: (HogWild)
How about the obvious, the red wire goes to the positive terminal and the black wire goes to the negative terminal.
This reminds me of an old post where everyone was giving this guy pointers on why his wires kept smoking and blowing fuses. After about 20 posts I posted the above message and he did indeed have the wrong wires on the wrong battery terminals, lol. But I have to hand it to him, he was honest and admitted his mistake.
Old 08-30-2005, 08:14 AM
tegsirg94's Avatar
Default Re: (Sam92Teg)
check and make sure you didn't turn the power cable into the starter housing while tightening the nut. Wire can't touch anything but that stud otherwise sparks will fly.
23LX23
10
11-19-2016 06:08 PM
redman223
Audio / Security / Video
05-04-2007 02:51 PM
hb_guy
04-09-2006 06:43 PM
sLoWrAcEr
04-19-2005 08:34 PM
Quick Reply: Reaplacing clutch.... smoking battery wires
