Radiator Help
cant find my old raditator.. what are you trying to do? if your bleeding your system you should jack it up and if you jack it up you should be able to see the valve.. acually i have a pic of my NEW raditator and the bleeder is in the same place here it is
- see the bottom right where the large hose goes to the left of that.. its kinda hard to see cus this one is black but on a oem one its in the same place and is white.
and before you make a new thread on somthing eles
try searching here it helps alot..
Re: (ho9984)
There is a bleed screw, however i have never used mine, Best way i have done it is:
Remover the radiator cap, start the car, let it idle with the HEAT ON FULL BLAST!!!, let the fans turn on twice, once they have done that top off the radiator if you need to, replace the cap and go for a drive. Over the next couple of days watch the temp and check the overflow tank, but you should be just fine.
Re: (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech »</TD></TR><TR><TD CLASS="quote">Actually there is a great thread the DC2 strated and i help in, search for it, with his username. It will answer a lot of questions</TD></TR></TABLE>
yea Racermech helped out alot.. good guy
lando griffin
07-22-2008 09:45 PM
dmxsoulja3
11
12-16-2004 10:03 PM
