Please help with Tie Rod and Under Ball Joints.
Old 11-25-2013, 07:51 PM
MegustaVtec's Avatar
Default Please help with Tie Rod and Under Ball Joints.
Last night I checked under the car because when i take of from a stop sign I can hear a pop sound. Driver side. My first thought was axles but I can turn with no clicking noises and axle boots are still in good condition. Can this be my problem a bad tie rod? and while I was down there I notice that the under ball joints are okay?. Front has some squeaking noises when going over uneven pavement. Suspension is not older than one year. Any advice is a appreciated.
Old 11-25-2013, 10:01 PM
B_Swapped93's Avatar
Default Re: Please help with Tie Rod and Under Ball Joints.
That lower ball joint is FINE, the inner tierod boot on the other hand should be replaced, yes you can still drive it around but put it on your to do list asap. replace the inner tierod it's self while you're at it you'll need a special tool tho 50$ or so when I got mine.
google123
08-25-2011 11:42 AM
Luke G.
03-22-2009 02:39 PM
phongadong
05-07-2008 09:12 PM
spicoli
01-10-2005 10:13 AM
Propulsion
08-03-2002 08:52 AM
Quick Reply: Please help with Tie Rod and Under Ball Joints.
