PCV valve not connected
Old 06-28-2007, 04:13 PM
jorge59la's Avatar
Default PCV valve not connected
i just realized that my PCV valve is not connected to the IM. its just sitting there with nothing comming out of it.
What does that mean?
Is this bad?
Should i replace the valve and connect it to the IM?
thanks...
Modified by jorge59la at 7:42 PM 6/28/2007
Old 06-28-2007, 07:56 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: PCV valve not connected (jorge59la)
The PCV valve routes unburned fumes from the crank case back to the IM so it can be burned and catalyzed. It also serves to relieve pressure inside your crank case.
Since its venting into the atmosphere, its relieving pressure.....but it's also polluting the air more than it should be. Reconnect it if you like to breath.
Old 06-28-2007, 09:08 PM
Kyoto now's Avatar
Default Re: PCV valve not connected (B serious)
All the PCV valve does is vent unburned fuel vapors back to the combustion chamber, along with a little oil residue. The inside of your IM will look like a dirty chimney after time, though.
Old 06-28-2007, 09:29 PM
jorge59la's Avatar
Default Re: PCV valve not connected (Battle Version)
i guess thats when the catch can comes in!
Old 07-03-2007, 09:05 PM
MidwestCivic's Avatar
it also sucks unburnt fumes from your oil so it doesnt get contaminated, you WANT that connected
kb58
03-24-2011 10:38 AM
justint
12-27-2006 04:33 PM
petrv
08-26-2005 02:26 PM
dr juice164
07-11-2004 10:04 AM
1.8T_EG
11-19-2002 03:05 AM
Quick Reply: PCV valve not connected
