Oil fumes inside car
Ok trying to hold onto this old teg. Just hit 273k. I did the head gasket and timing belt at 250k (bent valves). Just put in a clutch at 265k. Car currently has 273k.
Ever since I redid the head gasket ive been getting oil fumes inside the car, when I sit in traffic or let it warm up in the morning. A hose broke off of the underside of the intake when i pulled the head (missed it). It was extremely brittle. It came out of the black box on the back of the block and went up to one of the intake runners.
Im certain thats why im getting the fumes and loosing oil but how do I remedy this? Does that piece remove out of the intake? Or is it made into it? Here is a picture to help describe what im talking about.
1. is the box
4. is the piece in the intake runner
The hose in between 4 and 3 was broken off.
Lastly where can I find these parts? LPS have a hard enough time finding engine mounts for this car.
Thanks.
1. is the box
Thanks.
Re: Oil fumes inside car
What I need to know is can I just pop out the number 4 fitting and replace it and the hose, and where can I get the part?
Or are you saying that the hose passes through number 4 and through the intake runner and connects to number 8? I dont see how that would work.
Number 4 is the part in the intake that the valve goes into.. It does go to number 8. Number 3 goes to the block I believe. You can buy hose 4 with the fitting at honda
Thank you very much, that makes perfect sense.
Ill will be in touch with my honda parts guy tomorrow.
BTW I assume that number 4 should be removable? The old piece is extremely hard, but the new piece should be some what pliable? Like a grommet?
