How to remove stuck banjo bolt on fuel filter
Old 01-08-2024, 05:06 PM
JxR
JxR's Avatar
Default How to remove stuck banjo bolt on fuel filter
Anyone know what tool I specifically needs. I’m too afraid to force it off with a wrench, everytime I give it a little force the whole fuel filter moves around you can see some scratching on the edge of the cap as a result from that.
Old 01-08-2024, 08:12 PM
JRCivic1's Avatar
Default Re: How to remove stuck banjo bolt on fuel filter
You will need to use a wrench large enough to fit the large red hex on the top of the fuel filter just under the banjo bolt to hold the fuel filter steady while you loosen the banjo bolt... with a 17mm or 19mm wrench if you haven't already stripped it.
JxR
frossteedhehe
04-08-2013 09:36 AM
2kstreetcivic
01-18-2005 07:42 PM
cvc323
06-29-2003 11:09 PM
Andrew 825SM
10-30-2002 08:49 PM
samdawgsol
05-13-2002 09:40 AM
Quick Reply: How to remove stuck banjo bolt on fuel filter
