Need help on how to install HID into 92 DA
Old 01-19-2005, 11:14 AM
peel17's Avatar
Default Need help on how to install HID into 92 DA
I have a Audi Projector and a ballast w/D2s bulbs.
Need instructions on how to retrofit the projectors and how to install ballast.
Old 01-26-2005, 11:28 AM
peel17's Avatar
Default Re: Need help on how to install HID into 92 DA (peel17)
anyone?
Old 01-26-2005, 12:00 PM
B2FiNiTY's Avatar
http://www.skafia.com/itr/hid/
That should start you off.
Old 01-26-2005, 12:43 PM
peel17's Avatar
Default Re: Need help on how to install HID into 92 DA (B2FiNiTY)
kool thanks..
But I need a How to on a DA stock headlight
Old 01-26-2005, 12:45 PM
mike g's Avatar
have you checked g2ic.com?
i am looking to do the same on my DA but not audi projectors i think something else, not sure though
Old 01-26-2005, 01:10 PM
peel17's Avatar
Default Re: Need help on how to install HID into 92 DA (mike g)
i've posted and no replies yet.
Old 01-26-2005, 01:24 PM
ambiguous's Avatar
try http://www.hidplanet.com/forums
Old 01-26-2005, 02:30 PM
latindc2's Avatar
Default Re: Need help on how to install HID into 92 DA (ambiguousasn)
Does the DA headlights come with halogen projectors? if they do just follow the skafia article...
Old 01-26-2005, 02:43 PM
peel17's Avatar
Default Re: Need help on how to install HID into 92 DA (latindc2)
nopes
Old 01-26-2005, 08:52 PM
JDMlyfestyle's Avatar
One thing that is often over looked is a wiring harness.
Stock honda wiring is only good for 10 amps MAX!
HID's can draw almost double that during warm up which will fry your stock wiring fast.
I would recomend making or buying a wiring harness.
I make them in my spare time. i have a FS thread in my signature. if you search topics that i made i did a write up on how to make a wiring harness.
Old 01-26-2005, 10:01 PM
Slain's Avatar
I agree a wiring harness is a must dont run current through stringy oem wires.
try searching for memeber cjls he has done the retrofit with i believe hella bixenons
Old 01-26-2005, 10:07 PM
Cjsls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peel17 &raquo;</TD></TR><TR><TD CLASS="quote">kool thanks..
But I need a How to on a DA stock headlight</TD></TR></TABLE>
the thing is there is no one specific way of doing this.....every way is gonna be different. check my username on g2ic i think the post is still there from when i did mine.......that might help.
edit....did you say stock da headlamp? remember thats glass lens and metal housing, that one is gonna be a tad bit harder than the plastic type jdm one pieces. took me about 35minutes just to pry apart the glass lens versus about 10 minutes with the jdm one pieces.....anyhoo let me know if u have any ?'s...
Modified by Cjsls at 1:18 AM 1/27/2005
Old 01-27-2005, 07:13 AM
peel17's Avatar
Default Re: Need help on how to install HID into 92 DA (Cjsls)
okay, well.. that will be on hold for awhile until i figure something out.
So for now.. since i have a ballast and a D2s bulb in hand.. does anyone know how to make this work into a Stock DA?
dubcityb20
Lighting
02-24-2011 06:10 PM
Seks
Honda Civic (2001 - 2005)
12-17-2008 07:34 PM
alscrx
08-18-2008 08:47 PM
MikeTV
07-05-2005 07:37 PM
Grease Monkey
04-25-2004 08:19 AM
Quick Reply: Need help on how to install HID into 92 DA
