LS intake manifold on GSR head
My friend bought a car thinking it was a regular GSR (kid's dumb...). Well, when i looked at it, i noticed the block code was b18b. I called the guy up who he bought the car from and he said it was an LS/vtec.
The car is much slower than what an ls/vtec should be, so im actually doubting this car... the manifold is an LS and was wondering if this was possible, to put an LS IM on a GSR head (im guessing he did it for money purposes?), or did this guy just some how throw a vtec valve cover on an LS block?
im really confused with this car and what to think about it. Your imput would help my friend out a bunch. Thanks
Ryan
[Modified by tegasaurus, 3:07 PM 12/9/2002]
Ryan
Re: LS intake manifold on GSR head (tegasaurus)
a LS IM would not fit on a GSR head unless you do some modifications, because the holes for the forum wont line up correctly. if its ls/vtec, find out with head it is, B16 or B18.
You're probably confusing it with a first generation b16a intake manifold or even b17a intake manifold. They all look VERY similar. If its a VTEC head and the flange of the intake manifold does not look rewelded/redrilled or tampered with, it is a stock manifold of one of the above mentioned types.
Re: LS intake manifold on GSR head (teg92)
I'm actually now recalling the head had the code pr3 on it, if htat helps... as much asi know about vtec (limited, im a non vtec lover), that stands for the b16 head... yes? or is that just the code for vtec or seomthing... im still lost and confusing myself more.
[Modified by tegasaurus, 3:46 PM 12/9/2002]
PR3 is the code for 88-91 non-OBD b16a's, aka first generation B16A's from japan. When LS/VTEC's are done they typically use the intake manifold that came with the head, and in your case everything sounds just fine!
Here's a quick pic of that I pulled from an eBay auction.
thanks a bunch teg92... one more question
Since the head is a non obd (pr-3) head, what ECU should he be running or does it matter?
thanks.
ryan
thanks.
ryan
crxowner
02-22-2006 12:12 PM
