Lift points
Old 05-05-2003, 01:54 PM
ssbgsr's Avatar
Default Lift points
Need to raise a 98 Gsr & put on jack stands - changing brake pads. Where are the front and rear lift points? I'm putting the jack stands on the point used by the sissor jack for tire changing.
Earlier posts mention the tow hooks, front and rear & the support under the radiator; can any one confirm?
Thanks
Modified by ssbgsr at 3:14 PM 5/5/2003
Old 05-05-2003, 01:58 PM
MachAF's Avatar
Default Re: Lift points (ssbgsr)
look in owners manual.
Old 05-05-2003, 03:17 PM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssbgsr &raquo;</TD></TR><TR><TD CLASS="quote">Need to raise a 98 Gsr & put on jack stands - changing brake pads. Where are the front and rear lift points? I'm putting the jack stands on the point used by the sissor jack for tire changing.
Modified by ssbgsr at 3:14 PM 5/5/2003</TD></TR></TABLE>
If you don't know where the points are, are you sure you can change your brake pads?
Old 05-05-2003, 03:19 PM
Havokmkr's Avatar
Default Re: Lift points (Deluzional)
If you've ever been under your car before then you would see there are 6 jack points on the car. One up front in the center. Tow hook in the back. 2 spots by the front and rear wheel on both sides of the car.
Old 05-05-2003, 03:28 PM
OBDI JEDI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">
If you don't know where the points are, are you sure you can change your brake pads?</TD></TR></TABLE>
ahahahha
Old 05-05-2003, 03:51 PM
VTECorona's Avatar
Default Re: Lift points (OBDI JEDI)
Be nice guys
Old 05-05-2003, 03:58 PM
ssbgsr's Avatar
And I thought this was a friendly place! In my orginal post I basicly said I knew where the 4 on the sides of the car are, could I get a bit more of an exact description than "there is one in the front".
Old 05-05-2003, 04:04 PM
VTECorona's Avatar
If you look under the front end of the car you will see a hump kinda. It's on the frame on the radiator support part. You can't miss it.
Old 05-05-2003, 04:06 PM
P1mpSlap's Avatar
Default Re: Lift points (97RedTegGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97RedTegGSR &raquo;</TD></TR><TR><TD CLASS="quote">If you look under the front end of the car you will see a hump kinda. It's on the frame on the radiator support part. You can't miss it.</TD></TR></TABLE>
It's the front Tow Hooks
Old 05-05-2003, 04:14 PM
VTECorona's Avatar
Default Re: Lift points (P1mpSlap)
I use the center one.
Old 05-05-2003, 06:23 PM
tC_Dragon's Avatar
i've used all of the above mentioned places... but i tend to use the tow hooks. But if you are lookin for the center one in front there is an arrow pointing to that area under your car...
archstanton
11-21-2007 02:05 PM
vltnolia
05-29-2007 11:57 AM
Regular Series
12-01-2005 06:37 PM
tbud454
11-03-2003 07:55 AM
gsr94
09-24-2003 02:27 PM
Quick Reply: Lift points
