JDM catalytic converter?
Will a JDM catalytic converter fit my 99 dc4. will a JDM cat converter pass emissions(stock dc4 with basic intake and exhaust)? plans to do a JDM ITR header with JDM cat covnerter with S2 exhaust to bring inner diamete pipes to 2.36" all the way front to back.
Daisy... Daisy...
Re: JDM catalytic converter? (silentdeath12886)
The secondary O2 sensor bung is too small on the JDM converter. I had to weld a new bung. SInce you are using the JDM header, etc. it should fit.
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdeath12886 »</TD></TR><TR><TD CLASS="quote">kool, so what about a jdm cat converter passing emissions?</TD></TR></TABLE>
I thought that it would. I have a chipped OBD2 P72, so they never did the sniff test on my car. I passed since I did not have and CELs stored.
The JDM converted doesn't have any excessive odor or what not. Sorry I can't provide a better answer.
Re: JDM catalytic converter? (Dogginator)
bump.
well i know japan has a less strict policy in terms of emissions cause i know most JDM engines fail emissions. thinking maybe the cat converter is a factor.
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdeath12886 »</TD></TR><TR><TD CLASS="quote">bump.
well i know japan has a less strict policy in terms of emissions cause i know most JDM engines fail emissions. thinking maybe the cat converter is a factor.</TD></TR></TABLE>
Possibly. Japan typically runs 100 octane gasoline.
well i guess ill get the cat and if it fails i guess ill go with carsound or something like that...something i know passes emissions and cut off the flanges and weld them on the carsound cat.
boarderfatty
06-05-2015 11:26 AM
PirateTypeArgh
05-06-2006 07:05 AM
