intake valve stuck open...
Old 05-26-2007, 11:19 AM
RoB316's Avatar
Default intake valve stuck open...
i have an intake valve stuck open and i was wondering if there was a way to fix that while the head is still in the car???
Old 05-26-2007, 11:22 AM
Daisy... Daisy...
Dogginator's Avatar
Default Re: intake valve stuck open... (RoB316)
Why is it stuck open and how do you know that it is stuck open? Is it a leaking vlave determined by a lea-down test or is it actually open? You will most likely need to pull the head.
Old 05-26-2007, 01:09 PM
RoB316's Avatar
Default Re: intake valve stuck open... (Dogginator)
i did a compression test on the motor and it had 0 psi. by the way, its a freshly rebuilt motor with all new rings and seals and gasets. plus it is like coughing through the intake manifold whenyou open the throttle. which leads me to believe that theres an intake valve open.
Old 05-26-2007, 01:35 PM
thewrai6th's Avatar
If a valve is stuck open from being bent, the answer is no.
Did you pull the valve cover and turn the motor over by hand? Check your cam gears too.
Old 05-26-2007, 04:30 PM
Daisy... Daisy...
Dogginator's Avatar
Is the compression 0 psig in all cylinders? Did you adjust the valves? Did you recheck the cam timing?
Old 05-26-2007, 07:02 PM
adamrich33's Avatar
its probly not stuck open it might be broke ive seen it happen twice in a year on two dif hondas
Old 05-27-2007, 05:24 PM
RoB316's Avatar
Default Re: intake valve stuck open... (adamrich33)
no the compression is around 200 on all but number 1 and this engine was JUST rebuilt i have only started it like 5 times since the rebuild. can it be stuck open without being bent??
Old 05-27-2007, 05:26 PM
qfast817's Avatar
did you forget a dowl pin?
Old 05-30-2007, 04:10 PM
RoB316's Avatar
Default Re: intake valve stuck open... (qfast817)
i am doing a valve adjustment, but he adjusting nut is extremely hard to move, is there a trick to getting these to move?? i really dont wanna strip these out any help will be great thanks!!
Old 05-30-2007, 05:50 PM
Daisy... Daisy...
Dogginator's Avatar
The jam nut should release easily if all is well. If the jam nut is seized to the tappet adjusting screw, the screw should still loosen. If both the jam nut and tappet adjusting screw are seized, you may need to replace the affected rocker.
boosted94gsr
06-14-2014 10:13 PM
Noobatized
04-06-2014 04:19 PM
Rocket
281
03-06-2014 02:13 PM
rotascircuit
12-16-2009 02:58 PM
Quick Reply: intake valve stuck open...
