Intake Manifold Noise
Old 02-24-2003, 07:20 AM
ph0en1x's Avatar
Default Intake Manifold Noise
I have a 98 Ls and just recently my engine makes a humming noise coming from inside the intake manifold. It is not the whistling noise this is a loud humming noise when the engine is at idle. I have replaced the manifold and TB gaskets, but it still makes the stupid noise. What could it possibly be?
Old 02-24-2003, 10:44 AM
ph0en1x's Avatar
Default Re: Intake Manifold Noise (ph0en1x)
Can someone help me out?
Old 02-24-2003, 01:59 PM
Tweakmeister's Avatar
did you suck a leaf in there or something?
if nothing is in there it's probably a vacuum leak or loose bolt/nut.
Bear in mind the injectors make a little noise...but not a hum...more so a click.
Old 02-25-2003, 04:34 AM
ph0en1x's Avatar
Default Re: Intake Manifold Noise (Tweakmeister)
Nah I didn't suck up a leaf. That's what I think too. It has to be a vacuum leak somewhere.
Old 02-25-2003, 08:59 AM
ph0en1x's Avatar
Any one else have any other guesses wat it could be?
Old 02-25-2003, 09:06 AM
sk8phaze's Avatar
i have the same noise on my ls/vtec, i thought i was my headlamps making it until i starter hearing it idle in the day time
Old 02-25-2003, 09:36 AM
ph0en1x's Avatar
Default Re: Intake Manifold Noise (sk8phaze)
Did you ever find out what it was?
Old 02-25-2003, 09:42 AM
Pimpin Stef One's Avatar
did you replace it with a skunk2? if so, an important thing to remember is to make sure that the old gasket is COMPLETELY SCRAPPED off of the block. what happens is, most people peel it off and then they dont realize that the small parts of the gasket sticking on, will cause a leak. thus the noise. youre supposed to get all that **** off and make it CLEAN before you attach the new IM... or is this your stock one? do you have an intake?
[Modified by Pimpin Stef One, 6:44 PM 2/25/2003]
Old 02-25-2003, 09:57 AM
ph0en1x's Avatar
Default Re: Intake Manifold Noise (Pimpin Stef One)
Nah mine is the stock manifold and I made sure all of the old gasket was removed, I made the both look like new. stock filter also.
Old 02-26-2003, 04:25 AM
ph0en1x's Avatar
Any other guesses????
Old 08-18-2010, 02:17 AM
rexteg's Avatar
bringing back this hella old thread. but has anyone found out how to get rid of this hum sound coming from the intake manifold???
Old 08-18-2010, 09:06 AM
EHondaJDM's Avatar
No issues at idle?
Old 08-18-2010, 04:26 PM
rexteg's Avatar
i have issues at idle. same issue. humming from inside intake manifold. anyone know the fix?
Old 08-18-2010, 08:00 PM
vroomvroomparty's Avatar
Take brake cleaner and spray around the intake manifold, in light bursts. If you have a crack or leak, your rpm will jump. Use that to isolate the area. Could also be a loose IAT sensor.
usaf94civic
08-07-2009 02:59 PM
HonBlackSol93
10-03-2007 06:05 PM
blackie
07-19-2005 12:07 PM
Quick Reply: Intake Manifold Noise
