How to tell if the timing belt is bad?
Old 09-22-2010, 08:42 AM
dudesitsjdm's Avatar
Default How to tell if the timing belt is bad?
So i have had my gsr for a year and a half.I have seen alot of post of snapping timing belt's and i start to worry.First when i got the gsr it had a brand new head from acura.So it hought the belt would be new guess not.The teeth in the belt are all fine they still are rough inside but the top of the belt look's old and worn out.The tension is fine so how else can i tell if i need a new one?
Old 09-22-2010, 08:45 AM
mrchevez's Avatar
Default Re: How to tell if the timing belt is bad?
If im not mistaken thats how all timing belts look, they look worn out. If you have a timing belt that looks glazed than its time to change it unless you put belt conditioner but other than that if your timing belt teeth are good and no glazing and no cracks you should be good. I work at an auto parts store and trust me all of our timing belts look like they were manufactured ten years ago lol
Old 09-22-2010, 08:49 AM
Lol cool so if that belt look's new as hell i need to change it out. Thanks yea the teeth are nice and ruff.
Old 09-22-2010, 08:55 AM
mrchevez's Avatar
Lol not necessarily because like i said somebody could of put belt conditioner to make it shine but timing belts are all made looking old
Old 09-22-2010, 09:00 AM
H-T Order of Merit
nsxtasy's Avatar
In many cases, you can't tell from looking at it or feeling it. If it hasn't been changed in the recommended mileage OR time interval, or if you don't know whether or not it's been changed in that interval, just change it. The recommended interval for changing it is either 90K miles or 6 years, whichever comes first, or 105K miles or 7 years, whichever comes first. If you have an Integra on which it has never been changed, it's overdue. DO IT. If your timing belt breaks, you're looking at a very, very expensive repair (that may include rebuilding/replacing the engine).
Most people replace the water pump at the same time as the timing belt, because it's all the same labor to get to the water pump. If you've never replaced the cooling system hoses, it's a good time to do that as well, as a good preventive measure so you don't get a blown hose out on the road somewhere. (It saves coolant and labor by doing it at the same time as the water pump.) At least replace the two big coolant hoses at a minimum.
Old 09-22-2010, 09:11 AM
Ok thanks yea one of my coolant hoses nad a small bust on it.SO i cut it and extended it to fit.Im going to for sure by some new one's now.The teg has taken me to cali and nm twice i dont drive it a whole lot but i was thinking it is time to take care of her.Idk when the belt was changed but i will look into it.Should i buy a new water pump or a referbished one?
Old 09-22-2010, 09:14 AM
Drive 4 fun's Avatar
Belt, new water pump, and probably tensioner, all OEM.
Old 09-22-2010, 09:19 AM
Oem cost alot of cash is aftermarket somthing i want to avoid i found the water pump timing belt and tensioner on ebay for 70 bucks shipped.
Old 09-22-2010, 09:24 AM
I use plenty of aftermarket, but not for timing belt and waterpump. Guess you can get other opinions here.
Old 09-22-2010, 09:34 AM
Yea those are pretty major part's to go cheap on.My car never flux in temp and alway's stays one below middle of the temp gauge.
Old 09-22-2010, 10:18 AM
H-T Order of Merit
nsxtasy's Avatar
I wouldn't go aftermarket either, but that's up to you. I'm sure you're aware you can get 25 percent off OEM parts at dealers like Delray Acura and others.
Old 09-22-2010, 10:34 AM
dntnedvtec's Avatar
I would go OEM. Those are critical parts to your engine. I run The OEM water pump, timing belt, and tensioner. yeah, I paid $300+ for all of it, but I think its worth it.
Old 09-22-2010, 10:40 AM
I did not know that how do i take advantage of this?
Old 09-22-2010, 10:50 AM
Go here:
http://www.acuraoemparts.com/delray/jsp/home.jsp
When you look up parts, they show list and their price, 25% less, but, shipping.
Old 09-22-2010, 11:11 AM
H-T Order of Merit
nsxtasy's Avatar
Yes. If you had clicked on the dealer name in my previous post, you would have gone to the same link.
There are other dealers which offer discounts for mail orders. You can find some of them in this topic. (Yes, that's another CLICKABLE LINK in my post.)
Some dealer parts departments may be willing to give you the same discount in person, but you probably have to ask, maybe be nice to the guys in the parts department, tell them about what you can do elsewhere, etc.
qvminich
02-02-2021 11:38 AM
ShinobiLude
02-15-2007 09:03 AM
EJ1 wilcox
18
04-08-2006 01:55 PM
omeara7
07-08-2004 07:12 AM
GSRaCeRbOI
10-22-2002 06:34 PM
Quick Reply: How to tell if the timing belt is bad?
