how many gaskets for the vtec solenoid?
Hey, i have a oil leak from around the vtec solenoid/cam plug. I changed the cam plug and still leaking a little. How many gaskets are there for the solenoid, i believe i read somewhere that there were like 3. The big one that goes against the cylinder head and there are 2 other small ones?
Re: how many gaskets for the vtec solenoid?
Two on the vtec solenoid
You may not have put enough honda bond on the new cam seal.
If the vtec gasket is leaking replace with a new one and put a small thin bead of honda bond over the new gasket and instal for a better seal.
As far as i can see there is no oil coming from the cam cap, i felt around for oil to none from there.
