how can i fix my tail light?
hey i was wondering how can i fix my tail light because when i turn on my lights the back light dont turn on only the break light works. i try changeing the bulb but it is not working anyonegot any tip? =]
get an electrical engineering degree and then look to the wires for the problem. If it's not the bulb... its the wires or a fuse or something dealing with electricity. Relay maybe?
I hope you get shocked.
-Rik
-Rik
Re: how can i fix my tail light? (slickyo)
Aside from checking the fuse, In situations like these, First thing you do is check for continuity , to make sure there is current running through that wire.
Put one lead of a a test light to conductor of the wire, and the other to body(ground) ,
Light not going on means there is short somwhere on that circuti , Perhaps a pinche d wire.
immajackuup
05-07-2010 01:00 PM
devin_hoang
11-22-2008 02:27 AM
slowslow
11-07-2005 02:51 AM
