Need help on my timing
Old 06-19-2008, 04:43 PM
krazeenoy's Avatar
Default Need help on my timing
my timing is off ... i also have a skunk2 cam gear .. need help adjusting them
Old 06-20-2008, 06:05 AM
northemt88's Avatar
Default Re: Need help on my timing (krazeenoy)
set to 0 then set the timing then slightly adjust the cam gear
Old 06-20-2008, 06:10 AM
* B A N N E D *
St. Jimmy's Avatar
Make sure the cams are pointing up and the TDC mark on the crank pulley is lined up. Grab a timing gun and adjust the distributor while watching the marks on the crank pulley to get desired timing.
Ef4doorwagon
04-27-2014 01:57 PM
civiccoupe94
01-11-2008 07:08 AM
SOHC_MShue
04-20-2005 09:31 AM
Jorsher
10-24-2004 04:51 AM
Quick Reply: Need help on my timing
