Hood latch is not locking?
Old 02-16-2011, 06:28 PM
DAlexsanderC's Avatar
Default Hood latch is not locking?
Just bought a 2000 integra gsr, only problem is when i pull the latch its all loose and i think the cable is not going back in correctly. hood closes but doesnt lock and close all the way.
Anybody know what i can do? sorry not really a mechanic.
Old 02-16-2011, 06:34 PM
Hidenplanvew's Avatar
Default Re: Hood latch is not locking?
I had that problem on my civic, A simple cheap fix: get a can of wd40 and spray it on the latch and also try and spary some on the cable in the car at the lever. It worked for me, i had to shut my hood like 10-20 times before it would latch
Old 02-16-2011, 09:40 PM
ninjaturtleEG's Avatar
Try lowering the hood stoppers. The hood latch is adjustable by the way, though I'm not sure how.
Old 02-16-2011, 09:52 PM
ElementzofR's Avatar
the little plastic clip that holds the hood release cable onto the hood latch my have broken.
Old 02-16-2011, 10:08 PM
Dont think its broken just loose like the cable doesnt go back in like it should. The wd40 sounds like a good try tho. will try in the morning.
Old 02-17-2011, 04:00 AM
Bowl_of_Rice's Avatar
theres a little spring towards the front of the latch push it down and try closing it
Old 02-17-2011, 09:03 PM
Wd40 didnt work.. but idk i think it may need to be replaced..
Old 02-18-2011, 07:50 AM
1998GsRIntegra's Avatar
Mine does the same thing. If you clean your hood latch well and look straight down at it. On the bottom right side you will see a shiny piece of metal attached to the cable. It needs to be pushed to the left. Just use your finger and push it back to the left.
I can send you a picture of mine pointing to exactly what i'm talking about. Pm me your email if you want ill send you a picture of it. I think mine does it becaue of the angle the cable is at. It doesnt want to retract back after its been pulled.
Old 02-18-2011, 03:58 PM
thats how mine is, its like a little spring attached to a piece of medal i usually just use my finger but if i have a tool like a flat head ill use it and push it down or left it doesnt matter just push it in and then try to close the hood, there might be a little plastic piece in front of the spring you might have to pop it off
Old 02-18-2011, 04:19 PM
N/A
Purpose Built
N/A's Avatar
Third on that..
You can see right where the cable goes thru a lever, push lever to the left.
Not even pb blaster loosened mine up, lubing it won't always work
Old 02-18-2011, 05:27 PM
Hmm lol sounds like you guys all had the same symptom imma try tomorrow morning before work lol
Old 02-19-2011, 05:51 PM
Just tried it and it worked but im guessing its not a permanent fix? i have to do it everytime
Old 02-19-2011, 06:00 PM
Its permanent for as long as you feel like doing it. Lol. I have no problem with it. I guess you could try replacing the entire hood latch assembly if it gets annoying. I take it you got my email?
Old 02-19-2011, 06:04 PM
Yes sir thank you very much. Much appreciated!
efjones9
01-11-2009 01:04 PM
90si-rex
11
12-04-2008 07:05 PM
boostedhks
07-24-2008 07:45 PM
naterpatater77
02-29-2004 05:32 PM
scrolanky
01-21-2004 05:21 PM
Quick Reply: Hood latch is not locking?
