High idle and semi sputter
I was currently on here requiring help to get my car to start, quick run down. Had oil in the plug hole so my car wasn't starting, replaced the tube seals and spark plugs and it fires right up now, but now when i start it it idles at alittle under 2k and has a little sputter to it. Any idea's? My plugs could be gaped wrong would cause it?
Re: High idle and semi sputter
could be a vacuum leak,dirty IACV(IDLE AIR CONTROL VALVE) how's your coolant/oil level(make sure there topped up to the rights levels,best of luck;Matt
