hesitation issues under 3000 rpm
Old 04-21-2009, 07:34 AM
danteisme's Avatar
Default hesitation issues under 3000 rpm
i'm having a real hard time diagnosing this problem with my teg. it has a real hesitation issue under 3000 rpm. the problem doenst exist above 3000 rpm. it aslo doesnt seem to occur until after the car has warmed up. i will push my foot on the gas to accelerate and i can feel the car holding back. then all of the sudden it will jump and will start to accelerate like normal. no CEL's or anything. i've replaced the wires, plugs, cap, rotor, fuel filter, air filter has just been cleaned, i tested the coil and the ohms are with in spec. i'm not sure where else to check. i'm open to ideas.
here's a few other things about the car, 169K miles on it, about 90K on the motor, i replaced the entire exhaust 2 years ago, new cat, both new o2 sensors at that time.
96 gsr
Old 04-21-2009, 08:05 AM
tylersvols's Avatar
Default Re: hesitation issues under 3000 rpm
have you tried checking your ignition timing?
Old 04-21-2009, 08:06 AM
redlinetuning's Avatar
does this happen in all gears? say rolling at 30mph in 4th gear? Automatic?
how does it idle?
Old 04-21-2009, 08:07 AM
danteisme's Avatar
yes, timing is correct
Old 04-21-2009, 08:37 AM
danteisme's Avatar
idle is real good, 750+/-, and i cant say for sure if it happens in all gears. its most noticeable in 4rth and 5th under 3000 rpm
Old 04-21-2009, 08:57 AM
vwslayer's Avatar
do you have a gsr tranny or an ls?
Old 04-21-2009, 09:39 AM
danteisme's Avatar
i have a stock gsr tranny
Old 04-21-2009, 10:10 AM
vwslayer's Avatar
double check the gaps on your plugs and if those check out try advancing or retarding your timing... it pretty much has to be one of those
1998_4dr_gsr
12-04-2013 06:01 PM
thebigone
03-21-2009 04:00 PM
97BB6Type-SH
01-20-2009 01:42 PM
naTRON
06-02-2006 03:53 PM
turbotime
04-18-2004 11:05 PM
Quick Reply: hesitation issues under 3000 rpm
