have a few trouble codes cannot figure it out plz help!
New User
I'm gettin 6 codes the firsr 4 are cylinder misfires the 5th is random or mulitple misfire the 6th is a p1399 can't firgure wut it is
Re: have a few trouble codes cannot figure it out plz help!
Check your cat. Multiple random missfire is generally caused by a gasket leak bad ign coil or clogged up cat.
I would get the cat see if its clogged up. Check your spark and make sure your good and toasty on that and spary some starting fluid around the intake mani to see if you have any intake gasket leaks. Ill figure out what the p1399 for ya later
