Anyone have a Skunk Manifold on their GSR?
Old 08-05-2001, 07:46 PM
b18c1-ek's Avatar
Default Anyone have a Skunk Manifold on their GSR?
I am installing a Skunk2 intake manifold on a 1999 GSR. The EVAP purge control canister doesn't seem to have a place to fit on the new manifold... can someone tell me where they mounted theirs? Anyone have pics of the finished installation?
Thanks
Old 08-05-2001, 08:56 PM
GTEater's Avatar
Default Re: Anyone have a Skunk Manifold on their GSR? (b18c1-ek)
i just have mine hanging in the back....doesn't get in the way of anything
Old 08-06-2001, 11:29 AM
b18c1-ek's Avatar
Default Re: Anyone have a Skunk Manifold on their GSR? (GTEater)
How about the plastic canister on the bottom of the GSR manifold? Did u leave that hanging as well?
Thanks
Old 08-06-2001, 11:58 AM
GTEater's Avatar
i think that is the hardware to open up the 2ndary runners on the GSR manifold.....its got a bracket and a few vaccum hoses connected to it right?........just disconnect it from the wiring harness and remove it completely....you don't need it with the new manifold
Old 08-06-2001, 11:59 AM
New User
tiny's Avatar
Default Here's a pic of the finished install...
What are you doing with your throttle cable and bracket? And your coolant hose?
Old 08-06-2001, 12:42 PM
b18c1-ek's Avatar
Default Re: Here's a pic of the finished install... (tiny)
Tiny, where is ur EVAP purge control solenoid? Did u keep the plastic canister that was under the manifold? There is a sensor plug on that canister as well.... As far as the coolant hoses and throttle cable bracket, I need some advice on that too...
Thanks
Old 08-06-2001, 01:32 PM
stick's Avatar
Default Re: Here's a pic of the finished install... (b18c1-ek)
Thanks
as for that plastic canister (IAB solenoid) on the GSR manifold, i did use the sensor to its origin and i have mine hanging. the evap purge soleniod is hanging on mine but i have a T fitting that will connect to a vacuum line under the FPR.
i have a few pics of my install if u want i can email them to you
Old 08-06-2001, 02:08 PM
rockwilda's Avatar
Default Re: Here's a pic of the finished install... (stick)
man....my intake manifold set up looks nothing like the one above, i could take pics with my digicam right now if someone could post them and help me out
Old 08-06-2001, 02:28 PM
alexboy's Avatar
Default Re: Here's a pic of the finished install... (da_rockwilda)
tiny what tb are you using
Old 08-06-2001, 03:00 PM
GQ 05YellowEVO8's Avatar
Default Re: Here's a pic of the finished install... (alexboy)
It looks like an ITR T-body to me.
Old 08-06-2001, 03:47 PM
New User
tiny's Avatar
Default Re: Here's a pic of the finished install... (VTEC-MAN95GSR)
You're right, it's an ITR throttle body.
As for the canister? I don't know. I honestly didn't do the install myself. The throttle cable and bracket are from an ITR. And I do know that you'll need a longer coolant hose.
Old 08-06-2001, 04:23 PM
New User
ninjaman's Avatar
da_rockwilda: I'll host your pictures. Email them to me.
So we can get rid of the IAB vacuum unit (the plastic blank thing under the manifold) entirely with no check engine lights from the sensor? Good. One less piece to worry about securing.
As far as the EPCSV (evap) hose connection, I thought there was a place to connect it to. I got a longer hose because the OEM one was too short.
I'm not looking forward to undoing the factory wire loom for the IACV and IAT (the unit that bolts on the manifold next to the throttle body) because it's not reaching now.
Old 08-06-2001, 04:26 PM
New User
ninjaman's Avatar
By the way, for anyone who has used the GSR TB; did you have any leakage issues with the connection between the TB and the ITR AEM CAI? The rubber connector is way bigger than the TB, and I'd like to know now if it'll seal properly with just the hose clamp or if I'll have to put something on the throttle body to get it to seal correctly.
Old 08-06-2001, 04:34 PM
rockwilda's Avatar
Default Re: Here's a pic of the finished install... (ninjaman)
no leakage issues for me, just clamp it on pretty snug
ninjaman: you have mail
[Modified by da_rockwilda, 7:34 PM 8/6/2001]
Old 08-06-2001, 05:32 PM
non-VTEC's Avatar
tiny what do you have spliced into the PCV hose? where does that hose connect to?
Old 08-06-2001, 07:23 PM
New User
ninjaman's Avatar
Here's some pictures courtesy of da_rockwilda:
http://home.cfl.rr.com/blackbeautygsr/Mag00020.jpg
http://home.cfl.rr.com/blackbeautygsr/Mag00021.jpg
http://home.cfl.rr.com/blackbeautygsr/Mag00025.jpg
http://home.cfl.rr.com/blackbeautygsr/Mag00026.jpg
http://home.cfl.rr.com/blackbeautygsr/Mag00028.jpg
Old 08-06-2001, 07:36 PM
rockwilda's Avatar
thanks ninjaman
so yeah how do i get rid of the blue plastic object connecting to my PCV hose? its not harming my car or anything that i know of but its an eyesore to look at the bent hose and how its screwed onto the fuel rail..help
Old 08-06-2001, 07:51 PM
New User
wantmorepower's Avatar
did you guys feel any power after the install?
Old 08-06-2001, 08:02 PM
rockwilda's Avatar
Default Re: Anyone have a Skunk Manifold on their GSR? (wantmorepower)
pulls a bit harder after VTEC but since im basically stock..it feels a bit sluggish, i got CTR cams waiting on a valvetrain in my room, so sluggish no more will i be....well after money comes around
Old 08-06-2001, 08:35 PM
New User
ninjaman's Avatar
Personally, I don't think it looks bad and it's secure there. But you can always try putting the PCV (blue object) underneath the manifold like the above picture in this post and run the wires between the runners.
BTW, what does that small line (5/16") on the top far right of your manifold connect to?
Old 08-06-2001, 10:26 PM
Rhetoric's Avatar
That little canister you guys are talking about, I pulled it off. I believe I only have 3 sensors on the skunk manifold.
Old 08-06-2001, 10:35 PM
rockwilda's Avatar
Default Re: Here's a pic of the finished install... (G S R)
how does your manifold look like? could you post pics?
ninjaman: ill check in the morning where the hose goes and get back to you. i didnt do the install cause i tried and the gsr manifold was a b*tch to get off.
[Modified by da_rockwilda, 1:37 AM 8/7/2001]
Old 08-07-2001, 05:36 AM
newspeedR's Avatar
When you install the manifold with a gsr TB, do you still need to replace the throttle cable and bracket or can you use the existing 1...
Old 08-07-2001, 08:10 AM
New User
Go Mifune's Avatar
Default Re: Here's a pic of the finished install... (newspeedR)
read this: https://honda-tech.com/zerothread?id=54104
you can but you don't have to...
Old 08-07-2001, 09:58 AM
New User
ninjaman's Avatar
Just to let you guys know... I just got off the phone with Skunk2 and they said to use a t-fitting to connect the EVAP hose to the PVC hose, then connect then to the same fitting on the top front of the manifold.
Quick Reply: Anyone have a Skunk Manifold on their GSR?
