idles at 1k rpm
Old 03-07-2008, 10:27 PM
dc2_916's Avatar
Default idles at 1k rpm
im having a problem with my idle.. when i gas it and let go.. it drops down but it rev up by itself a lil.. i dont know wats wrong.. can it be the throttle cable?
Old 03-07-2008, 11:06 PM
SkaiWu's Avatar
? that is hard to understand but mine idles at 700-900 at operating temp and i was told it was normal
Old 03-07-2008, 11:33 PM
JDM-Riders's Avatar
Default Re: idles at 1k rpm (dc2_916)
1k is not too bad (can be normal)... If everything is stock and you never played with it, you can check the throttle cable to see if its too tight.
Old 03-08-2008, 01:54 AM
lv6l's Avatar
All stock idle for any car or make should not exceed 1000 rpm. It should always be somewhere between the range of 500-800 rpm. Of coarse this is under the condition the car is fully warmed up with the radiator fan spun at least twice.
Check your IACV and FITV. They are both located near the throttle body. FITV can cause high or low idles. IACV can cause idle to raise or lower after "gassing it a bit" Make sure connection is good and I would recommend you take off your IACV and clean it with some carb cleaner. Do the same to your FITV.
FITV is located right under the throttle body. It should have coolant hose connected to it. If you see none, that model motor did not come with one. It's okay if it never came with one.
IACV is located in back of the intake manifold. Between the intake manifold and firewall. It is near the throttle body. It also has coolant lines connected to it. Remove it and spray some carb cleanr in the holes to remove dirt.
I also recommend you removing your whole throttle body and spray/clean that down. Make sure you spray in all the tiny holes.
After doing all this, check for vacuum leaks around the intake manifold, you can check by spraying carb clean around there to see if there is a different sound in idle.
Make sure timing is correct, use a timing light to make sure No. 1 cylinder is firing at 0TDC. No. 1 cylinder is the cylinder closest to your power steering, windshield fluid, etc.
It would be best to use oem spark plug wires and spark plug. You did not mention what car and model or motor you are working with so I cannot give you specific details. Doing all this will not only cure your problem but make your car run like a champ again. Good luck.
Old 03-08-2008, 06:24 AM
dc2_916's Avatar
Default Re: idles at 1k rpm (JDM-Riders)
actually my car aint stock .. i have camshaft and cam gears but its set to retard -2 advance 2.. im running a stock 972 ecu.. can that be tha problem.. i remember last time i was messing with the dizzy.. could it be off timin also.?
Old 03-08-2008, 07:49 AM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2_916 &raquo;</TD></TR><TR><TD CLASS="quote">actually my car aint stock .. i have camshaft and cam gears but its set to retard -2 advance 2.. im running a stock 972 ecu.. can that be tha problem.. i remember last time i was messing with the dizzy.. could it be off timin also.? </TD></TR></TABLE>
Yep, one of those is your problem. You probably also need to clean your iacv. Is that a stock P72 or a chipped p72? Sounds like a chipped ecu to me...
Old 03-08-2008, 08:30 AM
dc2_916's Avatar
Default Re: idles at 1k rpm (95 integra)
i chekk the iacv alreadi.. and its stock p72 ecu.. untuned..
Old 03-08-2008, 09:32 AM
99j1zzer's Avatar
at 1k its pretty normal. did u check the tps?
Old 03-08-2008, 09:54 AM
95 integra's Avatar
Default Re: idles at 1k rpm (99j1zzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99j1zzer &raquo;</TD></TR><TR><TD CLASS="quote">at 1k its pretty normal. did u check the tps?</TD></TR></TABLE>
Funny because I've owned 6-7 GSRs and 1k isnt normal. 700-850 is "normal"
Old 03-08-2008, 04:22 PM
Blahblah718293's Avatar
lol cams will definetly funk your idle up if it goes below that it may stall out, but you can try cleaning your iac
(edit) also what lv6l said is all good info.
Old 03-09-2008, 10:03 AM
dc2_916's Avatar
Default Re: idles at 1k rpm (Blahblah718293)
i had tha cams gears in there for a while no problem watso ever of it stalling. but imma have to chek the thing thats under the throttle body.. i dont kno wats it called but heard people sayin it might have gotten loose so all i need to do it take it off clean it and tighten the things in the middle, hope it works ..doing it today
Old 03-10-2008, 06:20 PM
99j1zzer's Avatar
okey i might not own a lot of gsr but my gsr starts up at 1100-1200 rpm then when the engine warms up then goes down to 800-900rpm.
FATKID87
Honda CR-V & Element
03-26-2014 07:52 AM
smurf357
12-02-2012 11:33 AM
crxnonvtec
22
09-03-2009 02:52 PM
emooheo
03-23-2007 02:34 PM
ludedude808
10-18-2006 04:52 PM
Quick Reply: idles at 1k rpm
