h22 integra worth it?
Old 10-31-2005, 12:51 PM
gsrvtec2's Avatar
Default h22 integra worth it?
i wonder if an h22a integra swap is worth it? oppinionsss
Old 10-31-2005, 12:56 PM
BrooX's Avatar
Default Re: h22 integra worth it? (tekneshum)
No!
Old 10-31-2005, 12:58 PM
BrooX's Avatar
Default Re: h22 integra worth it? (DA9GUY-637)
But teally you would have to decide this because people all around have their own opinion on this. You will never get a straight answer because this has been beaten on many times which is why you should read the rules and then learn the search techniques. Everyone says search, because this has been covered 9,982 million times. So, In conclusion, you need to do these things before you post a worthless thread alright bro?
Old 10-31-2005, 01:00 PM
BrooX's Avatar
When I said 'but Teally' I friggin meant but Really. Dam I should proof read before posting
Old 10-31-2005, 01:34 PM
skunked's Avatar
H22 DC2
Old 10-31-2005, 01:43 PM
DarkBB4's Avatar
Default Re: h22 integra worth it? (skunked)
YES. h22 swap is AWSOME... besides adding awhopping 40-50 lbs up front... the ADDED hp and torque is great... also for a LOW LOW COST
u can pick up a long block for <2000 and ull make
160-180 whp with boltons
130-160 torque with boltons...
Thats as much as a na b16/b18c1 sometimes
Old 10-31-2005, 02:00 PM
skunked's Avatar
Default Re: h22 integra worth it? (DarkBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 &raquo;</TD></TR><TR><TD CLASS="quote">YES. h22 swap is AWSOME... besides adding awhopping 40-50 lbs up front... the ADDED hp and torque is great... also for a LOW LOW COST
u can pick up a long block for &lt;2000 and ull make
Thats as much as a na b16/b18c1 sometimes</TD></TR></TABLE>
OK, cant' tell if you are being sarcastic or not......but I made 199/164 with a NA Stock internal USDM H22 swap.
Old 10-31-2005, 02:10 PM
ozzyman's Avatar
I made 178hp and 152tq in my Integra with my JDM H22.
AEM CAI, dented really bad stock header, 2.25" 5zigen cat, VAFC.
Now I'm boosted.
Old 10-31-2005, 02:34 PM
Sifu's Avatar
I'd rather go for a small setup turbo Easier to pull more horse power out of later
Old 10-31-2005, 03:00 PM
gsrvtec2's Avatar
no kid, this thread is not useless at all. but ur input is USELESS!!! so GTFO!!!
Old 10-31-2005, 03:04 PM
gsrvtec2's Avatar
i've heard that h22 gives u lots of problems. what are the needs we need to make it right
Old 10-31-2005, 03:56 PM
NXLude's Avatar
Heres some advice, go over yonder to the ol' Hybrid and do some looking around....here Ill help you out:
https://honda-tech.com/zerothread?id=1131655
Old 10-31-2005, 07:06 PM
ozzyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekneshum &raquo;</TD></TR><TR><TD CLASS="quote">i've heard that h22 gives u lots of problems. what are the needs we need to make it right</TD></TR></TABLE>
What kind of problems? I've had mine for 2 years now. No problems at all.
Old 11-01-2005, 07:30 AM
skunked's Avatar
Default Re: h22 integra worth it? (ozzyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ozzyman &raquo;</TD></TR><TR><TD CLASS="quote">
What kind of problems? I've had mine for 2 years now. No problems at all.</TD></TR></TABLE>
Old 11-01-2005, 07:39 AM
HONDA RR's Avatar
No your better of getting a b-series motor
Old 11-01-2005, 07:43 AM
Moderator in Chief
Muckman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9GUY-637 &raquo;</TD></TR><TR><TD CLASS="quote">When I said 'but Teally' I friggin meant but Really. Dam I should proof read before posting </TD></TR></TABLE>
You do realize you can edit your posts dont you? No need to post 15 times in a row.
I also vote yes for H22. You'll make more power over a ITR motor for less.
Old 11-01-2005, 07:46 AM
skunked's Avatar
Default Re: h22 integra worth it? (HONDA RR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA RR &raquo;</TD></TR><TR><TD CLASS="quote">No your better of getting a b-series motor </TD></TR></TABLE>
and what's your reasoning? Have you owned an H22 hybrid?
Old 11-01-2005, 11:40 AM
* B A N N E D *
DC2SIR-G's Avatar
i am really curios of an h22 integra swap... but i heard people run through so many problems like more money out of their pocket because the motor is not that reliable. is this true? im still thinking about an h22 swap or a jdm GSR or.. maybe even a type R
Old 11-01-2005, 11:45 AM
skunked's Avatar
Default Re: h22 integra worth it? (tekneshum2)
if you want an "easy/no brainer" swap go with the B. The H is for the power hungry.
The H no less reliable than the B series IMO.
Old 11-01-2005, 11:47 AM
* B A N N E D *
DC2SIR-G's Avatar
i want my car to be fast.. like something that will hella pull when i step on the gas. but i really dont want to run through so much problems. what are the problems that you run into with your h22? or do you ride it and treat it like just another GSR.. but faster?
Old 11-01-2005, 02:40 PM
loudassVTEC's Avatar
H22
It's just too bad nobody makes mounts to put one in my DA, and I really don't feel like paying a shop
Old 11-01-2005, 02:45 PM
ozzyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekneshum2 &raquo;</TD></TR><TR><TD CLASS="quote">i am really curios of an h22 integra swap... but i heard people run through so many problems like more money out of their pocket because the motor is not that reliable. is this true? im still thinking about an h22 swap or a jdm GSR or.. maybe even a type R</TD></TR></TABLE>
So youre telling me a Prelude isnt just as reliable as an Integra? ALL Honda engines are reliable in stock form. They are built to last.
I run my car hard but I dont abuse it. Theres a big difference between the two. I see people who abuse their car and **** happens, but thats not because they have an H22 in their car or anything. Its the way they treat their car and it happens to anyone no matter what they drive.
If you treat it good, it will treat you good.
Old 11-01-2005, 03:20 PM
DippyDo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9GUY-637 &raquo;</TD></TR><TR><TD CLASS="quote">No!</TD></TR></TABLE>
Old 11-01-2005, 03:36 PM
radio1global's Avatar
I think this question goes back to what you really want the car used for. Im sure the H would be good choice if you wanted it for a 1/4mile/street racing type of car. But i would stick with the B series if you wanted to use the car for handling corners and road courses ect. Hence the 50lbs added to the front.
If you arent to serious about the build you can make some good WHP with headwork and bolt-ons on the H22. But same gains can come from a B series nonethe less, just more work.
Old 11-01-2005, 04:13 PM
* B A N N E D *
DC2SIR-G's Avatar
Default Re: (radio1global)
im leaning towards more to h22 swap. because i think that the stronger and faster the car, the more fun it is to drive daily, but i dont understand what makes h22 so hard to corner around and stuff? does it just break when i swerve or something?
Quick Reply: h22 integra worth it?
