Where does this go?
Old 01-02-2006, 12:12 PM
brewerdude's Avatar
Default Where does this go?
This is from the baggie that held all the cam holder bolts (putting car back together after replacing blown head gasket). It's much smaller than the head dowels and somewhat smaller than the cam holder dowels. The size is 10mm x 6mm. Can't figure out where it's supposed to go...
Old 01-02-2006, 12:14 PM
Daisy... Daisy...
Dogginator's Avatar
Default Re: Where does this go? (brewerdude)
From what engine is that? Check this site:
http://www.acuraparts247.com
Old 01-02-2006, 12:27 PM
V-takaroni's Avatar
Default Re: Where does this go? (Dogginator)
did you look inside the bolt holes in your timing belt cover? not sure what size they are but that might be one.
Old 01-02-2006, 12:41 PM
mattcivic's Avatar
Default Re: Where does this go? (V-takaroni)
that goes under yer center cam cap i lost mine on an old motor never put it in and motor ran jsut fine its always nice to have it there.
hope that helps
Old 01-02-2006, 01:43 PM
TypRice's Avatar
thats for the vtec pressure
between 2ed and 3ed cylinder with a o-ring around it....
dont forget that
Old 01-02-2006, 02:29 PM
WhoDoYouThink's Avatar
Default Re: Where does this go? (mattcivic)
looks like the dowel that goes under your head btween that and the block for the vtec oil pressure. 99% sure. ask a honda mechanic around your area though. that would be easy enough.
Old 01-02-2006, 02:58 PM
I requested a short story for a title.
stocker2shocker91's Avatar
Default Re: Where does this go? (2000turbogsr)
where do u get them diagrams from
Old 01-02-2006, 04:12 PM
mattcivic's Avatar
Default Re: Where does this go? (stocker2shocker91)
http://www.acuraautomotiveparts.org
$amGD3
11
04-16-2018 07:54 AM
forbiddenera
Engine Machining & Assembly
21
02-25-2018 10:13 AM
toxictom
05-25-2017 06:04 PM
Jeanious
02-27-2008 04:54 PM
sackdz
04-21-2003 09:42 PM
Quick Reply: Where does this go?
