Easiest way to separate axle and half shaft??
Old 12-04-2006, 03:18 PM
Hoppa's Avatar
Default Easiest way to separate axle and half shaft??
i need to separate my axle from the half shaft, and i was just wondering wat the easiest way to do that is?
Old 12-04-2006, 03:41 PM
JasonST's Avatar
Default Re: Easiest way to separate axle and half shaft?? (Hoppa)
Just gotta pull and tug until it comes out, sometimes it's kinda hard, just pull and turn until it comes out.
Old 12-04-2006, 03:44 PM
blkacgsr's Avatar
Default Re: Easiest way to separate axle and half shaft?? (JasonST)
you could use a long flathead screwdriver.
Old 12-04-2006, 03:54 PM
importdude2000's Avatar
pry bar
slowly pry little then push out
i found for my self that
if i pry+wiggle axle it comes off in a sec
Old 12-04-2006, 04:03 PM
skunked's Avatar
Default Re: (importdude2000)
beat it with a mallet
Old 12-04-2006, 04:23 PM
NH538DB8's Avatar
Beat it with a mallet while turning it. Thats the fastest way I've ever gotten it out. There has to be a better way to put those damn things in our cars. Such a pain in the ***.
Old 12-04-2006, 05:30 PM
Hoppa's Avatar
Default Re: (NH538DB8)
sorry wasnt specific enough, its not in the car the halfshaft and axle are outa the car and i need to separate the 2 peices
Old 12-04-2006, 07:30 PM
99Geeezer's Avatar
Default Re: (Hoppa)
do you mean pulling the axle from the intemediate shaft or cv joint off. the axle?
Old 12-04-2006, 08:22 PM
Hoppa's Avatar
Default Re: (99Geeezer)
ya i meant pulling the axle off the intemediate shaft
Old 12-04-2006, 10:03 PM
tjin83's Avatar
Default Re: (Hoppa)
yeah keep on tapping it with a rubber mallet
that's always worked for me
Old 12-05-2006, 12:52 AM
bg-33p's Avatar
Default Re: (tjin83)
BFH
Old 12-05-2006, 01:06 AM
F20Cteg's Avatar
Default Re: (teggysue)
Use a large rubber hammer, the ones that have the harder yellow rubber. Turn and bang. Quick hard wacks and it'll come out.
Old 12-05-2006, 07:38 AM
skunked's Avatar
Default Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">beat it with a mallet </TD></TR></TABLE>
beat it beat it!
Old 12-05-2006, 08:39 AM
Turbo O's Avatar
beat it like a pimp beats the hoe that spent up all the money.
Old 12-05-2006, 08:51 AM
PatrickGSR94's Avatar
I always use a large flathead screwdriver on the inner joint of the axle, and hit the screwdriver with a hammer.
appelsos
06-27-2011 07:29 PM
B18CYAAA
08-11-2007 04:38 PM
b20acura
02-25-2007 10:47 AM
huepowered
03-27-2006 12:33 PM
vha27
11-17-2003 07:27 PM
Quick Reply: Easiest way to separate axle and half shaft??
