96 ls brakes ???
Old 12-28-2010, 11:51 AM
b20teggie's Avatar
Default 96 ls brakes ???
got teg from brother last spring, brake pedal was super firm and stopped hard.
changed front pads last week and pedal is alittle soft. any ideas?? another issue is the ebrake. adjusted rear calipers and handle screws and brake still barely grabs. any ideas???
Old 12-28-2010, 01:19 PM
94 ls-r's Avatar
Default Re: 96 ls brakes ???
Bleed the brakes. Sometimes new pads will be a bit softer for a few miles. How did you adjust the rear? When I do a brake job I pull the hand brake up a few times till the slack adjusters get it tight.
Old 12-28-2010, 02:20 PM
b20teggie's Avatar
yeah got everything straightened out- just had to readjust the rear caliper pistons fron when i did the rear pads last fall- brakes are nice and tight again and ebrake only takes 4 or 5 clicks and its good
bboylito
09-21-2004 11:05 PM
GSRnold
08-22-2004 04:29 PM
mickey513
10-02-2003 04:35 AM
AK94GSR
05-30-2003 01:31 PM
tractoy
09-03-2001 06:11 AM
Quick Reply: 96 ls brakes ???
