Cv axle
Old 05-05-2014, 06:28 AM
slow_low_eddie's Avatar
Default Cv axle
So I changed out my driver side cv axle no problem. I was starting to remove the passenger side axle and the damn castle nut decides to be a PITA. I tried and tried and tried to loosen it but I'm sure it's seized.
Anyway, I read online I can just remove the lower control arm and I should be able to move parts aside to remove the axle.
Can anyone confirm this? I'm attacking this once I get off work at 1:30. Thanks!
Old 05-05-2014, 06:35 AM
B_Swapped93's Avatar
Default Re: Cv axle
the UCA/Tiered is easier imo vs the lca/sway bar stuff. which nut is it, the lower ball joint or upper ?
Old 05-05-2014, 06:54 AM
Thanks for the quick reply. So removing the UCA is easier for you? The lower ball one. That **** is stuck. Literally. Cheater bar and all. Still no budge.
Old 05-05-2014, 07:01 AM
Default Re: Cv axle
yes it's higher up thus not subject to as much road slim etc, the tierod end should be undone to then you can remove the cv.
Old 05-05-2014, 07:07 AM
I have no idea what you mean by road slim? Damn. So I must remove the outer tie rod too? While searching I read that people would just remove the UCA and boom. I just want to swap the axle so then I can take it to my mechanic where we can take that damn castle nut off.
Old 05-05-2014, 07:32 AM
Default Re: Cv axle
crap on the road brake dust run your finger on the bottom of the car you'll know what I mean. just the nut that holds it to the spindle(tierod) but may not be necessary.
Old 05-05-2014, 07:47 AM
Oh, haha. I probably would have understood road slime or something like that. But okay, cool. I'll remove the UCA and see if that'll be enough. Thanks for the help man.
Old 05-05-2014, 11:35 AM
I'm trying to remove the UCA but on the right side, it's a bit hard to reach the nut. How exactly do I remove this? Do I have to loosen the bolts from the engine bay?
Old 05-05-2014, 11:42 AM
Never mind! Got it!
Old 05-05-2014, 01:26 PM
Now both axles are changed. No more clicking or clunking sounds. However, driver side seems to be making a grinding noise maybe? Like a metal hitting another metal. I checked the rotor shield and it isn't hitting anything. What can it be?
hondaEg_808
11-27-2008 04:22 PM
C_Rock77
08-27-2008 11:19 AM
B18CYAAA
11-25-2006 01:22 PM
91zSi
30
08-04-2005 04:09 PM
JeremyL
05-02-2005 06:57 PM
Quick Reply: Cv axle
