coolant leak !
1 Post
Re: coolant leak ! (KanzenR95GSR)
passenger side dash board? like in the interior? huh? lol, if its dripping from underneath the motor, then you have a cracked radiator. this is common on all integra's. Mine took a crap on me last year...started noticing coolant on the ground, then my reservior tank kept going dry...replaced it and it works like a champ again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KanzenR95GSR »</TD></TR><TR><TD CLASS="quote">just the other day i found coolant leaking under the passeger side dash ? has anyone had the same problem or know why it could be leaking ? </TD></TR></TABLE>
I cant find that thread... soooo..
If there is in fact COOLANT, then you have a cracked heater core and to replace it, you must remove the dash.
If it is water, then it could be from the AC Evap drain tube, there is a rubber tube that drains moisture from the AC Evaporator under the dash. Make sure it is plugged in properly.
Re: coolant leak ! (Chris)
jdmfoglights
10-22-2017 02:16 PM
