Clutch Pedal
Old 05-13-2015, 07:38 PM
KillChris's Avatar
Default Clutch Pedal
So im doing the 5spd swap on my car , when buying the clutch pedal assembly do i need to buy all the pedals or just the clutch pedal assembly ?
Old 05-13-2015, 09:17 PM
wunfstgsr's Avatar
Default Re: Clutch Pedal
5 speed swap - Auto to manual parts list - Page 3 - Team Integra Forums - Team Integra
check page 2
Old 05-14-2015, 02:36 AM
B_Swapped93's Avatar
just the clutch pedal the large brake can be cut imo that's 10x easier then swapping the brake pedal over.
Old 05-14-2015, 12:59 PM
EnjoyTheRideDC2's Avatar
Is it really that much harder to replace the pedal assembly? The auto brake pedal will sit closer to the clutch pedal than it normally should. Sure, your suggestion is easier but is a perfect example of cutting corners..both figurative and literally.
AzntaggeR
08-08-2019 09:57 AM
DSRxSALSA
Welding / Fabrication
06-06-2008 07:45 PM
C_Rock77
08-16-2003 05:39 AM
fso_BamBam
06-29-2001 12:43 PM
Quick Reply: Clutch Pedal
