Cloud of white smoke out intake manifold
Old 09-02-2011, 04:02 PM
MGX
MGX's Avatar
Default Cloud of white smoke out intake manifold
went over to work on my buddy dc integra he had siting for 3 months put everything together an on the attempted to start a big cloud of white smoke came out the intake manifold. looking for ideas what would cause this i was thinking it was sucking oil into the manifold but how?
Old 09-02-2011, 04:05 PM
famous323's Avatar
Default Re: Cloud of white smoke out intake manifold
More likely to be a coolant leak, I say this from the white smoke, did you tighten down the head to specs? could be a leaking head gasket from not mating right to your block.
Old 09-02-2011, 04:21 PM
MGX
MGX's Avatar
the head should be on the right specs because we didnt remove that we left that on but might be from the coolent leak because there a crack on the bottom of the radiator but not a big leak we filled with water before start
Old 09-02-2011, 04:37 PM
famous323's Avatar
is there only white smoke visible coming from the manifold or are there any other areas its coming from?
Old 09-02-2011, 04:38 PM
famous323's Avatar
where exactly is white smoke coming from, pics if possible
Old 09-02-2011, 05:29 PM
MGX
MGX's Avatar
the smokes coming straight out from the TB and thats the only place it was a big puff cloud an i had to hold the TB to let all the smoke out that was left in there
Old 09-02-2011, 05:34 PM
famous323's Avatar
does it do this continuously? did you spray any type of solvent or carb cleaner in there it could be residue. try letting it run for awhile to see if it burns off.
Old 09-02-2011, 05:38 PM
MGX
MGX's Avatar
nope didnt spray anything in there it has a hard time staying runing im not by the car right now but ill try that tomarrow see if it still does it or burn it all away
Old 09-02-2011, 05:46 PM
famous323's Avatar
ok check back
Old 09-02-2011, 05:56 PM
MGX
MGX's Avatar
any idea of why it wont stay running unless you keep reving it an when you let the throttle go right before it cuts off it well idea at 3000
Old 09-02-2011, 06:24 PM
koss1229's Avatar
I think your intake manifold is not sitting right letting water get inside. That would also cause a vacuum leak. That would also explain the engine not running right.
Old 09-03-2011, 01:56 PM
famous323's Avatar
could be^ but he stated he never touched the head, was this motor running 100% before it was sitting? sounds like air/fuel mixture is not right, when you say the engine cuts off. so no more white smoke?
Old 09-03-2011, 02:02 PM
SkidmarkEH2's Avatar
Sounds like bad timing. the white smoke is fuel vapor meaning the car is some how backfiring
Old 09-04-2011, 05:13 AM
Technical Hero
HondaPartsHero's Avatar
This ^. Check your mechanical timing, sounds like it may have skipped a tooth. Thats the only situation where I've seen this happen with the smoke.
Old 09-04-2011, 10:01 AM
Hidenplanvew's Avatar
bent valve?
vonttcha
11-11-2009 06:54 AM
HondaKid936
04-05-2009 02:47 PM
streetcartuner
15
06-11-2008 03:11 PM
matix
09-13-2006 06:36 PM
Mjh787
18
06-14-2006 07:01 AM
Quick Reply: Cloud of white smoke out intake manifold
