check engine codes on my ls
Old 05-05-2006, 10:20 AM
96LsBang's Avatar
Default check engine codes on my ls
well i have a 1996 ls special edition, and for about 2 months now i've had check engine and maint req, lights on and the codes that show are P0420, P1336, AND P1337 I believe the first one is a o2 sensor code, i was wondering was that because i gutted my cat or would that not throw a code. any advise
Old 05-05-2006, 10:47 AM
gsrjrsc's Avatar
Default Re: check engine codes on my ls (96LsBang)
to reset you maint. req light look up under you dash and you will see a button hold that in and that will go away. If you cant find the button look in your manual it has a pic there
Old 05-05-2006, 11:25 AM
96LsBang's Avatar
Default Re: check engine codes on my ls (gsrjrsc)
thanks can anybody help with the o2 sensor problem
Old 05-05-2006, 11:31 AM
purplegsr's Avatar
The P0420 is a Catalyst System Efficiency below threshold code, so I would say that is a direct result of having a gutted cat.
The P1336 and P1337 are intermittent interruption and no signal codes for the Engine (Crankshaft) Speed Fluctuation Sensor.
Old 05-05-2006, 11:48 AM
96LsBang's Avatar
Default Re: check engine codes on my ls (purplegsr)
thanks for the information. how can i take care of the crankshaft code, or what would that be from
Old 05-05-2006, 11:51 AM
Hype-R Stalker
CleanLikeJdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">The P0420 is a Catalyst System Efficiency below threshold code, so I would say that is a direct result of having a gutted cat. </TD></TR></TABLE>
Obd2 isn't very fond of a gutted cat, Not sure about the crankshaft though.
Old 05-05-2006, 12:18 PM
purplegsr's Avatar
Default Re: check engine codes on my ls (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">
Obd2 isn't very fond of a gutted cat, Not sure about the crankshaft though.</TD></TR></TABLE>
Exactly, you might want to switch over to obd1, go to a high-flow cat, or an o2 simulator
As for the crankshaft speed position code, it could be a distributor, sparkplug, sparkplug wire problem. I believe the distributor has the crankshaft position sensor integrated into it, so you could try to get a new CPS harness. I would first replace your spark plugs and see if that helps, then test for connectivity with a multimeter (look in the helms manual at http://www.redpepperracing.com), and then replace the harness or the entire distributor, depending on the cheaper option. Sometimes buying a dizzy from distributorking is cheaper than replacing one expensive component.
allvtecyo
Honda Civic (2001 - 2005)
01-23-2013 02:37 PM
lilcdawg5950
07-06-2011 02:36 PM
EK9_GRL
10-08-2007 12:03 PM
bma1818
04-19-2006 09:55 PM
type r 01-1063
01-16-2004 11:52 AM
Quick Reply: check engine codes on my ls
