Changing auto tranny fluid on 2000 acura integra gs
Old 10-31-2004, 08:01 PM
racekar's Avatar
Default Changing auto tranny fluid on 2000 acura integra gs
I have done manual tranny fluid changes but i have never done an auto tranny on this car..
can someon write post some brief steps on how to? is there a tranny filter on the integra auto tranny or is is just a drain bolt and fill through the dip stick? thanks
Old 10-31-2004, 08:21 PM
DB8_TEG's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (dchung1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dchung1 &raquo;</TD></TR><TR><TD CLASS="quote">I have done manual tranny fluid changes but i have never done an auto tranny on this car..
just take the drain bolt out, clean the bolt off with a clean rag, tighten the drain bolt then fill it up via the dipstick and you are done.
No filter
Old 11-01-2004, 04:35 AM
JimBlake's Avatar
... And IF the fluid is brown or smells burnt, drive around a little & change it again. A couple times.
When you drain an auto trans, the torque converter doesn't drain, so you're only changing about 1/3 or 1/2 of the fluid.
Old 11-01-2004, 08:25 AM
m R g S r's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (JimBlake)
****, I should really do that on my 95ls, i haven't changed it ever!
Old 11-01-2004, 08:31 AM
TEXN3's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (m R g S r)
recommended changes should occur every 25k-30k miles.
it's about 60 bucks from the dealer. there is a great write-up at http://www.g2ic.com for doing a complete fluid change on a B18a integra, i'm sure the transaxle for the B18b and B18a are quite similiar, maybe some computer differences.
http://www.g2ic.com/forums/sho...fluid
note: you may have to be a member to view this...i'm not sure.
Old 11-01-2004, 08:49 AM
timmy8151's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (TEXNTEG)
Though the recommended interval is 25K-30K miles, I usually recommend 15K intervals. Fluid isn't that expensive and is easy to change, since there isn't a filter.
As posted above, a single drain and refill isn't going to change all the fluid. If you want to do a more thorough flush, do a triple flush as Jim Blake recommended.
Old 11-01-2004, 10:07 AM
LostGsr's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (timmy8151)
Here's another link:
http://www.c-speedracing.com/h...d.php
Old 11-01-2004, 10:52 AM
..::91TEG-G2::..'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">Though the recommended interval is 25K-30K miles, I usually recommend 15K intervals. Fluid isn't that expensive and is easy to change, since there isn't a filter.
As posted above, a single drain and refill isn't going to change all the fluid. If you want to do a more thorough flush, do a triple flush as Jim Blake recommended.</TD></TR></TABLE>
how much would this run you in fluid?
Old 11-01-2004, 11:20 AM
timmy8151's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">
how much would this run you in fluid?</TD></TR></TABLE>
Remember only to use Honda ATF, because of the Z1 additive. I've seen the fluid sell anywhere from $2.50 to $4 per quart. A drain and refill will require 3 qts per change.
Old 11-01-2004, 11:24 AM
MyceliuM's Avatar
At this website it shows how to change the automatic transmission fluid on a B18C1 engine. I have an '01 Teg Ls B18B1. Are the procedures still the same?
Old 11-01-2004, 11:34 AM
JimBlake's Avatar
Default Re: (MyceliuM)
Um, yeah. That link shows how to change fluid in a manual transmission. LS vs. GSR should be the same. And on a manual, pretty much all of it drains out.
But we were talking about an automatic. Drain plug is on the bottom somewhere, but probably a little different than the manual. And you fill it thru the dipstick hole.
Old 11-01-2004, 11:57 AM
MyceliuM's Avatar
Default Re: (JimBlake)
What's a dipstick hole?
Old 11-01-2004, 12:30 PM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyceliuM &raquo;</TD></TR><TR><TD CLASS="quote">What's a dipstick hole?</TD></TR></TABLE>
It's the hole, where the dipstick goes into the transmission. The dipstick is used to check the amount of ATF in the transmission.
Old 11-01-2004, 01:09 PM
LostGsr's Avatar
Default Re: Changing auto tranny fluid on 2000 acura integra gs (LostGsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostGsr &raquo;</TD></TR><TR><TD CLASS="quote">Here's another link:
http://www.c-speedracing.com/h...d.php</TD></TR></TABLE>
ahh my bad, yea that's the link to changing a manual transmission fluid. For the automatic, it's even easier. There's a plug on the transmission casing that a 3/8 socket drive will fit directly in it. Take the plug out and drain, then fill from the dipstick hole like Jim Blake indicated.
Old 11-01-2004, 02:43 PM
TEXN3's Avatar
nevermind...go with the link I posted above, it WILL answer your questions and give you thorough directions of what to do.
roterx7
Honda Civic (2001 - 2005)
05-12-2007 03:26 PM
egyolk
04-29-2005 12:33 PM
slowd16z6
12-12-2003 01:51 PM
ModlesSI
09-17-2002 01:22 AM
Quick Reply: Changing auto tranny fluid on 2000 acura integra gs
