Car is not starting (Clicking Noise everytime I turn the key)
I have a 93 integra and most of the time the car does not start when I turn the key it makes a clicking noise. When I turn the key repeatly i guess it catches a spark and thats the only way my car starts. I changed the whole distributor, cap, and rotor, not long ago. I HAVE NO IDEA WHATS THE PROBLEM!!! Help please? THANKS.
Re: Car is not starting (IntegraFroggie)
I'm making the presumption that you are confused. Is it not turning over? If it doesn't turn over it's not gonna "CATCH SPARK" as you say.
I think you meant it's not turning over but it's clicking. Is your battery fine voltage/amperage wise? I think the problem is probably a bad wire or more than likely the starter is all gunked up or needs replacement.
Location: Formerly of SF moved to DFW and now back in SF, CA, USA
Re: Car is not starting (Sack Master)
Clicking noise: bad battery or maybe alternator. How old is your battery?
When I'd get clicking noises it was usually my battery. Also check the alternator fuse.
