can a bent spring on the ignition coil cause misfiring?
Old 02-13-2006, 06:31 PM
drtyhatch's Avatar
Default can a bent spring on the ignition coil cause misfiring?
Just a quick question... i recently changed my cap and button and when i pulled the old cap off, the spring in the coil was caught on the little bolt on the inside of the cap, well now the spring is bent a little and i tried to straighten it out but i couldn't get it quite right. Car has never EVER had a misfire before this point. I will also add that timing belt, water pump, all oil seals and valve adjustment was just done aswell (AT ACURA). Now at IDLE the car will run perfect for a few minutes and then a misfire and then it will run fine again after the single misfire, I have replaced, plugs, cap and rotor, and i have NOLOGY wires. You guys have any suggestions, could that spring cause this?
Old 02-13-2006, 08:40 PM
teg racer 877's Avatar
Default Re: can a bent spring on the ignition coil cause misfiring? (drtyhatch)
just change the spring and see what happens, thats all you can really do at this point, just a cheap little spring right?
Old 02-14-2006, 04:51 AM
drtyhatch's Avatar
Default Re: can a bent spring on the ignition coil cause misfiring? (teg racer 877)
nope, you have to buy the entire coil.
Old 02-14-2006, 08:35 AM
tallyturbo's Avatar
it misfired for me i changed it and now im running fine
Old 02-14-2006, 11:01 AM
drtyhatch's Avatar
Default Re: can a bent spring on the ignition coil cause misfiring? (tallyturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo &raquo;</TD></TR><TR><TD CLASS="quote">it misfired for me i changed it and now im running fine</TD></TR></TABLE>
you changed the coil? was your car doing the same thing or was it breaking up while driving, my car seems to run fine when driving but has this slight misfire at idle. I know everyone probably thinks i'm just being ticky but this car has always ran like it was brand new and I have never heard or felt a misfire in it at all. Everyone I talk to seems to think its in the secondary ignition but i'm really starting to suspect the ignitor or the coil.
Old 02-14-2006, 11:02 AM
BrooX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drtyhatch &raquo;</TD></TR><TR><TD CLASS="quote">nope, you have to buy the entire coil.</TD></TR></TABLE>
Correct. Done this before...it's the right procedure.
Old 02-14-2006, 12:47 PM
drtyhatch's Avatar
Default Re: can a bent spring on the ignition coil cause misfiring? (BrooX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrooX &raquo;</TD></TR><TR><TD CLASS="quote">
Correct. Done this before...it's the right procedure. </TD></TR></TABLE>
Do you mean replacing the coil is the correct thing to do in this situation?
thanks for the input guys
Old 02-14-2006, 12:50 PM
tallyturbo's Avatar
ya when my car would go into boost it would break up really bad. i dunno what the prob was and then last saterday it finally got bad enough where it wouldnt crank. so after eliminating everything else it could possible be we figured it was that coil. a new coil for a b16 at advance auto was like 75 bucks. i slapped it in and it fired right up. no hesitation. now it rides smooth
oh ya and before i replaced the coil the actual coil itself was bent. i dunno how it got that way but it was. i tried fixing it but i couldnt.
Old 02-14-2006, 06:59 PM
drtyhatch's Avatar
alright well i replaced the coil and the car is still misfiring. Any ideas?
ezcape
04-25-2011 05:54 AM
RotaryPWR
03-16-2010 10:32 AM
rice a roni
12-14-2006 07:31 AM
Quick Reply: can a bent spring on the ignition coil cause misfiring?
