Bottom end gaskets
Old 02-26-2014, 02:42 PM
rak511's Avatar
Default Bottom end gaskets
May sound dumb to some of you but just want to double check before I start ordering stuff... Just got an obd2 oil pump that didn't come with the o ring or gasket... So just double checking part numbers this is what I found from Honda...the oil pump gasket (where it connects to the pickup) is the same for 94 and 00... so im guessing that all those gaskets are the same... for the o ring I found the 94 and 00 had different part numbers, id guess the obd1 pump used a different o ring than the obd2 oil pump does... And finally this may sound like a stupid question, but are all b series oil pan gaskets the same? I looked at the part numbers on Honda and they are all different. 94 ls is 11221-pr3-000, 2000 gsr is 11221-p72-000, and 2000 ls is 11221-p30-004... Are they all the same? The engine in my car is an obd1 ls-vtec, b18b1 block and b16 head. Which oil pan gasket would I use?
Old 02-26-2014, 03:10 PM
Eg.ls.turbo's Avatar
Default Re: Bottom end gaskets
Get either one. the gsr and ls oil pan gasket they are all the same. Te only difference from a gsr and ls oil pan is the gsr has a deeper pan but same shape as ls oil pan.
I've used a gsr oil pan, gsr oil pan gasket, pickup tube,vtec oil pump, and girdle on my ls turbo and fit just like an ls oil pan. U just need all those parts with it to b able to have the gsr oil pan to work.
sh!ft
11-28-2010 11:30 AM
Romodavid15
03-16-2010 08:16 AM
keychild486
03-02-2009 12:07 PM
Civiclx
11-12-2007 06:27 PM
B16CivicEX
06-22-2006 05:53 PM
Quick Reply: Bottom end gaskets
