best cams for ls motor?
Old 01-07-2004, 03:59 PM
JdM_Ls_PwR425's Avatar
Default best cams for ls motor?
what are the best cams i cam use for my ls motor for street/strip?
Old 01-07-2004, 04:02 PM
backlash's Avatar
Default Re: best cams for ls motor? (JdM_DoHc_PoWeR425)
I think Crower seems to be the most popular brand. People will argue between the 62403 vs 62404.
Old 01-07-2004, 04:13 PM
90teg's Avatar
Default Re: best cams for ls motor? (backlash)
404's all the way.
Old 01-07-2004, 05:50 PM
JDMThoughts's Avatar
Location: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
What kind of power are you looking for? Do you have some set HP goal, or E.T? Camshafts will give you a slight increase in power, depending on their design, but to fully get their real power you new cam gears, and head porting, maybe some valvetrain components as well, depending on the apps. Turbo cams vary from all-motor cams as well, I have friends with Skunk2 cams and they swear buy them and I have a friend with JUN IIIs and that thing is unbelievable.
Old 01-07-2004, 05:54 PM
91tegrals's Avatar
well since you have a ls you will not be running any skunk or jun **** so i would say the most taked about cams out there are crower then jg and there are others out there web cams, crane i have a set of jg 303 cams for sale let em go cheap if you want them hit me up....
Old 01-07-2004, 06:00 PM
Default Re: (91tegrals)
how cheap? are the jg cams good? i heard they made sum cams for ls motors but i have heard no feedback on how the performance is.... let me know a price and let me know how they perform..
Old 01-07-2004, 06:04 PM
Default Re: best cams for ls motor? (JDMThoughts)
im plannin to have around 220-240 hp in my motor...im tryin to find a good place to send my motor to so they can port and polish it and get a multi-angle valve job.. do u know of n e good places to send my head to? i want to get skunk 2 cam gears along wit my cams. I'm also going to get crower valve springs and retainers. i got many plans for my motor but i need to know wat the best cams are for my motor... i heard crower was good but thats all i hear about cams for an ls...
Old 01-07-2004, 07:03 PM
91tegrals's Avatar
well ill let them go for 175$ there bigger then the crower 404s i have not actually had them in my car cause my motor is going out fast so i never put them in but have heard they pull good in the higher rpms and they rev too like 8.5 so you will need a ecu chip but i have hearsd they pull good so um let me know if you want them....
Old 01-07-2004, 07:20 PM
djay86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM_DoHc_PoWeR425 &raquo;</TD></TR><TR><TD CLASS="quote">im plannin to have around 220-240 hp in my motor...im tryin to find a good place to send my motor to so they can port and polish it and get a multi-angle valve job.. do u know of n e good places to send my head to? i want to get skunk 2 cam gears along wit my cams. I'm also going to get crower valve springs and retainers. i got many plans for my motor but i need to know wat the best cams are for my motor... i heard crower was good but thats all i hear about cams for an ls...</TD></TR></TABLE>
Do you expect this engine to be streetable? You are really pushing it for 220- 240 whp! I would say 200-210 at the most... and this is with a b20 bottom end/ crazy compression/ biggest cams possible/ excellent portwork/ and a standalone fuel management system.
I would say the best cams for an LS motor are Crowers. If you are looking to get the most power out of your engine get the Crower 405's. These are not the 405a's these are the 405's with .502 lift. You will need to get your head machined to allow cam clearance.
Crower or Crane, i say make the best cams for ls motors. They are made from billit cores, not regrinds.
Old 01-07-2004, 08:24 PM
Indiana Jones's Avatar
Default Re: best cams for ls motor? (djay86)
404's are the usual but all motor LS making that type of power you'd better upgrade.
Old 01-08-2004, 01:07 PM
CRX T-Si's Avatar
Default Re: best cams for ls motor? (NA Gen2Teg)
I had the Crower 403's with the duel valve springs before on my first LS motor and it ran good.
The idle on it was a little ruff but it ran good. Back when we had emissions I never passed so depends on your needs.
I tried it for turbo and it did not work for me plus Crower said that it have too much overlap for FI. (just letting you know)
topped out my car at 134mph at 7200rpm with it.
Old 01-08-2004, 01:10 PM
b00sted4dr's Avatar
Default Re: best cams for ls motor? (CRX T-Si)
i had 403's when i had an ls. I ran it with my stock valvetrain and it was great. It would idle like stock also. But eventually got bored of and would have went with 404's. If you plan on getting springs and retainers, i'd say 404's all the way.
Old 01-08-2004, 06:53 PM
Default Re: best cams for ls motor? (96gsr4dr)
are ur crower cams up for sale?
Old 01-08-2004, 09:51 PM
silvernick711's Avatar
The most commen cams I have seen used in b18b1's are the crower 403's or cranes that are close to the duration and lift as the 403's
Old 01-09-2004, 03:33 AM
91tegrals's Avatar
if you want a good eal on crower cams check out ebay theres a few on there for a decent price...
LaOstha
08-03-2006 09:16 PM
93LSivic
03-21-2003 07:01 AM
CBR600OnTop
01-14-2003 07:05 PM
JCracer723
09-08-2002 06:07 PM
4U2NV
01-14-2002 07:42 PM
Quick Reply: best cams for ls motor?
