b18b rods arp rod bolt torque..torque spec?
Old 11-12-2005, 07:06 PM
psegs80's Avatar
Default b18b rods arp rod bolt torque..torque spec?
When torquing the arp rod bolts on stock b18b rods, do you use arp torque specs or honda?????
Old 11-12-2005, 07:31 PM
non-VTEC's Avatar
Default Re: b18b rods arp rod bolt torque..torque spec? (psegs80)
use the specs that ARP gives you with their rod bolts
Old 11-13-2005, 07:29 AM
psegs80's Avatar
Default Re: b18b rods arp rod bolt torque..torque spec? (non-VTEC)
That's what I did and now my crank is very hard to turn and I put new green oem rod bearings wich are the same color has before???
Old 11-13-2005, 07:31 AM
psegs80's Avatar
Should the rods be in the same sequence has before or are they all the same...cause when I sent my rods of the the machine shop for them to press my p30 pistons, I didn't mark them?
Old 11-13-2005, 08:22 AM
Mad Scientist
mmuller's Avatar
your crank is hard to turn now because the new higher torque spec of the arp's are making your rod ends egg shape causing clearances to go way off.
you have to have a machine shop hone your rod ends round again
Old 11-13-2005, 09:10 AM
psegs80's Avatar
Default Re: b18b rods arp rod bolt torque..torque spec? (mmuller)
So when I get the rod ends hone I will need new spec rod bearings right??? And can I just send off the rod end or full rods or the bottom end???
Thanks!
Old 11-13-2005, 09:19 AM
Mad Scientist
mmuller's Avatar
you can send them the rods. Clearances can remain the same and can be made all the same, sent them to a reputable machine shop; they will have no problems getting it dead on.
Old 11-13-2005, 09:33 AM
psegs80's Avatar
Should I be able to use same rod bearings size???
CivicSD
03-14-2010 01:15 AM
EG hunter
04-08-2007 09:25 AM
b2Ovtec
11
05-11-2004 12:51 AM
inFamousOneSix
07-09-2003 12:29 AM
senpai
06-05-2003 09:34 AM
Quick Reply: b18b rods arp rod bolt torque..torque spec?
