will a stuck thermostat make ur cooling fan not turn on?
Old 06-24-2008, 08:56 AM
EFOwNzALL's Avatar
Default will a stuck thermostat make ur cooling fan not turn on?
my DA's fan isnt coming on and its running hot, i just changed the head gasket so i didnt have any coolant in the motor but when i checked everything after the new HG i noticed tht the fan didnt turn on even after the engine had warmed to almost over half
thanks
Old 06-24-2008, 09:09 AM
steveharrmr23's Avatar
Default Re: will a stuck thermostat make ur cooling fan not turn on? (EFOwNzALL)
not really no cause there is no electrical connections but if you have your thermostat set to hot air in the car and the fan running it is possible that will keep your car cool enough to not need to run that fan also in junction with the air temp outside the car
Blaze45
03-08-2018 02:57 PM
dth0ng69
01-28-2009 06:19 AM
DCshoecompany
09-10-2007 11:23 AM
wsiracerz
06-07-2004 12:08 AM
vtec69
01-16-2003 08:06 AM
Quick Reply: will a stuck thermostat make ur cooling fan not turn on?
