ac removeal
Re: ac removeal (zeroz)
I don't believe it yields any hp gains but it takes a bit of weight off if you remove the entire unit.
Unless it's strictly a track car and every pound makes a difference, save yourself the discomfort and leave it in.
(If you say you dont use it thats a lie because i hardly ever use mine but when its horribly humid out on a rainy day in the middle of august, you bet your *** my ac is blowing at max power!)
ya i wouldnt remove it...i almost did..but since i havent had ne ac due to my ac pump going out, in the middle of july, im deff going to be saving money to fix it..cuz it sucks not having ac blowing on u..esp when raining.....its soo damn hard to see when ur windows fog up...well thats my 2 1/2 cents......
it eliminates a belt.... and a lot of weight, and will give better air flow, if you can deal with the heat for a few minutes you could take it out, once you are moving fresh air is just fine....
personally, i took mine out for my turbo clearance
if u do rip it out, i'll buy the front piping from you.
the pipe that runs across the radiator from the driver side to the passenger side.
i need that pipe for the longest!
thanks
I need pipe 7 and 8
thanks
I need pipe 7 and 8
Cogent Argument Enthusiast
Re: ac removeal (rkrone)
im taking my AC out before i install my turbo kit. the AC has needed a charge since i bought the car about 2 years ago; i just got used to it. it doesnt bother me. you will save about 100lbs if you take out the AC.
Re: ac removeal (benb18a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benb18a »</TD></TR><TR><TD CLASS="quote">im taking my AC out before i install my turbo kit. the AC has needed a charge since i bought the car about 2 years ago; i just got used to it. it doesnt bother me. you will save about 100lbs if you take out the AC.
its not 100lbs, its more like 20-30
Re: ac removeal (BolivianDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianDc2 »</TD></TR><TR><TD CLASS="quote">
its not 100lbs, its more like 20-30</TD></TR></TABLE>
my bad. my friend just took the AC out of his 240; he said it was abotu 100lbs of ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benb18a »</TD></TR><TR><TD CLASS="quote"> you will save about 100lbs if you take out the AC.</TD></TR></TABLE>
I wish!!!
I wish!!!
Re: ac removeal (B18CDD)
its reallly tempting because of turbo clearance but i don't know.... i don't know if i want to go through the hassel of tryin to have AC and Turbo.......
Re: ac removeal (b18ccivics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics »</TD></TR><TR><TD CLASS="quote">
power and comfort </TD></TR></TABLE>
valve cover is grounded wrong...
I felt gains in the midrange right away, when i took the belt off.
The whole system is pretty heavy. The heaviest part being the compressor, but you still have the dryer, condenser, evaporator, lines, fittings etc...it deffinetly adds up! It's at least 60lbs worth of dead weight.
Re: (teddy_dc2)
The actual weight is 44-46lbs, my friend and I both took ours out of our G3 Integras. Stop posting grossly erroneous numbers, I see everything from 20-100lbs in this thread.
IdotheSHOCKER
10
06-25-2002 11:18 AM
