1998 integra whistle noise
Old 11-28-2009, 08:47 PM
almostjdmeg's Avatar
Default 1998 integra whistle noise
I have a 1998 integra gsr with a b16 and a pro series intake manifold. While driving no matter what gear i am in at a ceartain throttle position i hear a whistle that sounds like a turbo, but i have no turbo. It doesnt happen in nuetral, only when im moving and in gear. Please help.
Old 11-28-2009, 10:08 PM
dohcvtak's Avatar
Default Re: 1998 integra whistle noise
do u have a bigger throttle body too along with with the im?
Old 11-28-2009, 10:10 PM
no, its the stock throttle body from a gsr
Old 11-28-2009, 10:18 PM
ILS_09's Avatar
If the whistle noise is coming from your intake, there's nothing wrong. It natural for the intake to whistle sometimes if the noise is coming from your intake. I went through two set of different intake and both made the whistle noise.
Old 11-29-2009, 04:16 AM
yea i know that, but if it were the intake whistleing then wouldnt it whistle while the throttle was being pushed while the car was in nuetral? Thats why i cant test it sitting in my driveway. lol
Old 11-29-2009, 06:52 AM
redline760's Avatar
maybe u have an exhaust leak.
Old 11-29-2009, 09:00 AM
Zach614's Avatar
Sound like it is just your intake. Mine does the same. No biggie.
Old 11-29-2009, 10:41 AM
artin01's Avatar
ok its not exhaust leak and it has nothing to do with a intake manifold or the intake. beacuse i had a 98 gsr and i had a same problem which i posted a while back a go. i had stock intake stock echaust system. dont think somthing is wrong with your motor too beacuse thats what i though my mechanic did leak down test and comparison test and my motor was perfect. whatever it is its not a big deal.
Old 11-29-2009, 10:46 AM
Zach614's Avatar
how can you be so sure it's not his intake. i know of lots of aftermarket intake pipes that whistle. mine does it all the time.
Old 11-29-2009, 12:38 PM
huckaboo's Avatar
this may sound really weird but turn off your radio and go for a spin! sometimes certain head units make a high pitched noise like a whistle. it only happens when your driving. im not sure why but it does happen.
Old 11-29-2009, 02:31 PM
lol, i already gave that a shot. Thanks for the response though
Old 11-29-2009, 03:39 PM
dszer89's Avatar
its must be ur intake mine does it too
Old 11-29-2009, 03:48 PM
bakertime's Avatar
It's the stock throttle body, and it's 100% normal and OK. The stock airbox muffles the sound, so it isn't noticeable until you put an aftermarket intake onto the car. My GSR does this also, and if you look around you'll find that most others do also.
The reason you can't hear it while parked is because the engine isn't under enough load to have the throttle at that position for long enough to sustain the whistle.
Old 11-29-2009, 04:21 PM
madblkscientist's Avatar
its the intake at a certain rpm or load my sk2 mani whistle like a turbo and at vtec my gas peddal resonates it tickles lol
Old 11-29-2009, 04:22 PM
konad's Avatar
Check your exhaust for one of these? (sorry I had to)
http://www.youtube.com/watch?v=eSOSJ68xOBA
Old 11-29-2009, 07:20 PM
^^^^LMAO^^^
Old 11-29-2009, 08:27 PM
exist12's Avatar
HAHHAHAHHAH! WOO WOOO!!! only in the mornin only in the mornin..you supposed to be up cooking breakfast in the morning...its like an alarm clock.
dude...IT'S YOUR INTAKE/THROTTLE! The whistle occurs when you open the throttle by PUSHING the accelerator. The combination of high suction and a small throttle creates the noise. If you have a friend, tell him to play with the throttle in neutral, pop open the hood you'll hear it.
Old 11-29-2009, 11:16 PM
artin01's Avatar
Because I had a stock intake system on my car and the car was making the whistle noise still so I know for a fact it wasn’t the intake my friend. Here is the picture
Old 11-30-2009, 07:52 AM
b20btegg's Avatar
it is the intake, thats a common sense question
Old 11-30-2009, 10:52 AM
jdmlove2006's Avatar
dude dont worry about lol sorry man it has to be your airbox/intake/throttle body your getting worked up over nothing this very common my integra did it at about 4200 rpms and I could hold it there so it made this noise
Old 11-30-2009, 11:11 AM
artin01's Avatar
Agree^
Old 11-30-2009, 11:41 AM
Moi Zver' (GSR)'s Avatar
i have changed my throttle body to Skunk2 70 mm and it would make this whistle noise at 2600 rpm, sounds just like a turbo.
Old 12-01-2009, 07:55 AM
eight equals equals equals D
Tim2179's Avatar
It's your intake. And for some reason, no it wont make the whistle while it's in neutral.
I got bigger cams so now I can't hear the whistle...
Old 12-01-2009, 08:24 AM
RedMenDC2's Avatar
it seems like you intake doesnt look like a GS-R...it looks like a LS intake! did you check your intake manifold gasket or your throttle! cause my GS-R has a short ram intake that blows like turbo...its running fine and strong?
Old 11-13-2019, 12:12 PM
Edmyester's Avatar
I have a 99 gsr after installing a new cold air intake I have noticed the same sound
Adankid
10
06-28-2008 07:01 AM
ramennoodles
10-05-2004 03:28 PM
sslude
02-17-2003 05:14 PM
crxtreme27
08-31-2002 11:49 AM
Quick Reply: 1998 integra whistle noise
