1996 Integra, I can't find the ECU jumper cable to check my CEL code
Old 11-16-2006, 11:52 AM
xunkn0vvnx's Avatar
Default 1996 Integra, I can't find the ECU jumper cable to check my CEL code
I have a 1996 integra and I can't seem to find the ECU jumper connector to short to find out why my check engine light went off. I pulled off the kick panel and also unscrewed the glove compartment,
Can somebody post a picture of what the connector looks like?
Old 11-16-2006, 11:56 AM
88civic's Avatar
Default Re: 1996 Integra, I can't find the ECU jumper cable to check my CEL code (xunkn0vvnx)
i have a 2001, so i cant give you a pic but it should be just below the glove box close to the door!!! good luck!
Old 11-16-2006, 11:57 AM
jfruauff's Avatar
Its a 2 pin little green plug above ecu.
Old 11-16-2006, 12:33 PM
* B A N N E D *
GRAF-FITI's Avatar
Default Re: 1996 Integra, I can't find the ECU jumper cable to check my CEL code (jfsrt4)
or you can run to your local autozone and have them plug in the OBD2 code reader for FREE...this should be on the passenger side of the console behind the carpeting next to the cupholder area
Old 11-16-2006, 01:31 PM
95 integra's Avatar
Default Re: 1996 Integra, I can't find the ECU jumper cable to check my CEL code (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">or you can run to your local autozone and have them plug in the OBD2 code reader for FREE...this should be on the passenger side of the console behind the carpeting next to the cupholder area</TD></TR></TABLE>
Autozone FTW!!! Its actually not by the cupholder, but on the very far passenger side of the glovebox on the little 2" strip on the right side of it.....way up under there. Basically bottom of the glove box and to the right about 2"s. If you aren't flipped upside down in the passenger seat, then you aren't gonna find it.
Old 11-16-2006, 01:51 PM
Kyoto now's Avatar
Default Re: 1996 Integra, I can't find the ECU jumper cable to check my CEL code (95 integra)
On my girlfriend's homosexual 96 Accord it's behind the ashtray, what the hell was honda thinking?
MonKK
11-15-2008 12:22 PM
JDM Vision
05-03-2006 05:09 AM
Schaz
11-05-2004 11:06 PM
lowboost civ
03-31-2003 08:20 AM
V8T8E8C
03-18-2002 11:04 AM
Quick Reply: 1996 Integra, I can't find the ECU jumper cable to check my CEL code
