01 type R oil pump on 94 gsr block....
Is it alright to have a type R oil pump on a gsr block? can I just get a type r timing cover to fit the new oil pump?? TIA
Re: 01 type R oil pump on 94 gsr block.... (PainfulTeg)
the type r oil pump will work fine on any b series motor. it's actually a good buy because it has a high flow gear in it.
Re: 01 type R oil pump on 94 gsr block.... (urbanracer98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanracer98 »</TD></TR><TR><TD CLASS="quote">the type r oil pump will work fine on any b series motor. it's actually a good buy because it has a high flow gear in it. </TD></TR></TABLE>
Exactly!
Exactly!
Re: (boostteg97)
is i possible to use this same itr pump or gsr pump in place of ls pump building ls'vtec i know i will have to use a vtec timing belt if i have a b16 head b18b bottom end can the vtec parts don't i use a vtec timing belt ???????/
Re: (99 ls integra)
almost the same as above...i'm getting a B20B and turbo, oil cooler, and i was looking at getting a ITR oil pump...will this work, or be beneficial?
Re: (ScootinIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScootinIntegra »</TD></TR><TR><TD CLASS="quote">almost the same as above...i'm getting a B20B and turbo, oil cooler, and i was looking at getting a ITR oil pump...will this work, or be beneficial?</TD></TR></TABLE>
the R pump will work fine four your app.
Enough said on the subject, the first two to three posts were enough. The question asked could have been answered by itself, Type R oil pump on a GSR block, hmmmmmmmmmm an exact fit higher flow oil pump (B-series VTEC) on a GSR block(B-series VTEC)?hint, hint..... You make the call, and do a search next time you may just answer your question befor resorting to posting.
Re: 01 type R oil pump on 94 gsr block.... (Gerhard_001)
Hey Gerard....
Calm your *** down dude....if you knew so much than you should have said something before....AND it is NOT a direct fit since you have to buy the 01 R timing cover because the outline of the pump is different than a GSR pump.....chill man and stop whining.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PainfulTeg »</TD></TR><TR><TD CLASS="quote">Hey Gerard....
Calm your *** down dude....if you knew so much than you should have said something before....AND it is NOT a direct fit since you have to buy the 01 R timing cover because the outline of the pump is different than a GSR pump.....chill man and stop whining.</TD></TR></TABLE>
yeah dude.....chill out.....
Are you 100% sure about that timing cover thing ? I put an ITR oil pump on my 98 LS and my plastic covers went on just fine.
Re: 01 type R oil pump on 94 gsr block.... (AzSi22)
so 96 + oil pump from a gsr or itr pump are interchangable for and ls with no mods to the oil pump does the same hold true for the crv fuel pump and water pump i went to advanced auto parts and they were the same part number for the fuel pump they look identical to i ask because the acura parts cost more than the honda ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">96+ Integras have a CFK sensor that 94-95 don't have. So, the covers are different.</TD></TR></TABLE>
^ Correct.....or you could modify the 94-95 and make it fit.
Re: 01 type R oil pump on 94 gsr block.... (pro1342)
DOES THAT MEAN CORRECT FOR THE JUST THE GSR OIL PUMP ,FUEL PUMP AND WATER PUMP WILL FIT ON AN LS OR CORRECT THE CRV PARTS FIT ?
Re: 01 type R oil pump on 94 gsr block.... (99 ls integra)
GSR/SI/Type-R oil pumps are the same, will fit LS and CRV.
LS and CRV water pumps are the same, different from the VTEC pumps.
The fuel pump doesn't matter, hell a Mitsubishi 3000GT VR-4 AWD twin-turbo fuel pump fits........it's all about how much flow you need.
thanks so your saying 99 civic si and 96 +del sol vtec pumps ie water pump, fuel and oil will fit on ls . i only asking cause i don't want to order ne thing that won't fit / i 've had heard about the the fuel pump a mechanic also told me how to take mitsubishi 400cc injectors and put it in a integra so your right on the flow
