IL del sol sir 15"
the file i attached, has the wheels (usually found on jdm oem 92-95 civic sir) i wanted until i found out they are 5.5 inches. all pre 2000 4x100 oem honda wheels came no wider than 6 inches and offset of 45. since your wheels are oem del sol wheels and same chassis as the civic and pre 2000, i could only assume they are 5.5 or no more than 6 inches with the offset of 45. i want someone to prove me wrong so i could have more reason to buy your wheels that is if your wheels are 6.5 inches.
I assume these are 15" diameter and 6.0" wide like other oem honda rims I've seen. I am really interested in the offset as well. I have seen pics of these rims in black and gold as well.
Look on the rims is should say JJ55 or JJ6, that gives you the width. Please make sure they are 15inch. and look around for a +45 or +38 or a number in that range, that is the offset, if its not on the outside you might have to dismount one and look around on the inside to be sure.
These rims are pretty rare but I don't think many people care about getting them; supply is low, but so is demand. I am interested in the history and where you got them from, edm, jdm, or usdm etc.
If you had gold or black I would be all over it but silver is just ho-hum to me, good luck with sale.
where r u located? city? or state?
FrostyDC4
20
Jun 6, 2002 03:00 PM
