would rays lug nuts work?
Old Apr 30, 2007 | 01:47 PM
kleen98accord's Avatar
Default would rays lug nuts work?
i just bought lug nuts from rays. they seem pretty big. would they work if i plan on using them on my sportmax wheels.
becuase my old wheel locks weren't that big.
do ray lug nuts only work on rays wheels?
thanks
Old May 1, 2007 | 07:07 PM
pli's Avatar
pli
Default Re: would rays lug nuts work? (randomvtec)
they should work. it might just look like a super tight fit.
Old May 2, 2007 | 02:27 PM
KCustoms's Avatar
Rays lugs are just made to work very well on rays wheels but you can put them on whatever wheels you have don't really matter.. I have rays lugs on my mugen wheels and they work fine..
Old May 2, 2007 | 05:34 PM
team-savage's Avatar
i'm pretty sure that as long as the rims require a tapered lug nut it should work.
Old May 3, 2007 | 11:26 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by randomvtec &raquo;</TD></TR><TR><TD CLASS="quote">i just bought lug nuts from rays. they seem pretty big. would they work if i plan on using them on my sportmax wheels.
thanks</TD></TR></TABLE>
I ran Rays lugs on my 5Zigen wheels. In fact, I would wager the very tight clearance due to the large nuts would help with protecting the wheels, its very hard to get a tool in there with so little space. The flat black I had looked very nice too, when new.
However, after 6 months of using them, swapping wheels once a month for autocross, my Rays lugs were already starting to show signs of wear and damage. The first thread in each nut was starting to separate from the nut. Never allowed an impact to get anywhere near them, always torqued by hand with a torque wrench, they're just that soft and weak. In fact, when I lost my 7 sided lock key, a couple of hammer taps was all that was necessary to use a 19mm 12-sided socket on them. They are soft enough that you can force them into the socket, with the socket bending and cutting into the metal to fit, to remove them. Took the mechanic all of 5 minutes to remove all 20 of my lugs, including the 4 "locks", without any special tools.
WhiteDc4Integra
Jan 16, 2010 03:26 PM
ninjaturtleEG
Sep 11, 2009 10:22 PM
jdmbooth
Nov 9, 2007 10:36 AM
VTECTIME
Oct 16, 2002 03:48 PM
Flux
Apr 23, 2002 05:55 PM
