Work Meister question
Old Aug 15, 2010 | 01:56 PM
Rude Awakening's Avatar
Daughter not possible
Default Work Meister question
Okay, I'm looking to not have ill-fitting wheels. Close to the fender, no stupid camber, or wrong offset that means cutting and pounding stuff.
So.... Can I get Meister that have the flatter spokes for my car, or would I have to have the "bubble face" version? For the wheels to fit CORRECTLY? Car is a Prelude 5th generation. Same question for Enkei RPF1.
Do not want:
Do want:
RPF1
Do not want:
Do want:
Old Aug 15, 2010 | 06:31 PM
chargeR's Avatar
Default Re: Work Meister question
Regarding the RPF1s they only get that style of face in 17" and above and 9" and wider. Available offsets in 17x9" are +45, +35 and +22 all in 5x114.3 I believe so if you think you can fit any of these sizes under your car without doing any of the cutting and pounding that you mention then you will be fine.
2 piece Work Meister S1s come in a few different face designs depending on the diameter and I think you want the low 'O' disk type to get the flatter centre style but this will affect brake clearance. What diameter, width and offset were you hoping to get?
Old Aug 15, 2010 | 06:51 PM
Well, RPF1 are out. 17x9 definitely require things I dont wanna do. Higher offset would rub inside the well/suspension, and obviously, lower means OMG hella flush.
I need a normal offset, like + 35 and 7.5 to 8 wide on the Meister. They would be 17's.
Ferg
Jul 31, 2013 03:36 AM
apbtwhiskey
Mar 19, 2013 09:34 PM
coopsekb18
Mar 8, 2012 02:22 PM
jdmer4life
Nov 11, 2008 12:55 PM
DA KING
Oct 17, 2004 07:04 PM
