wondering?
Old Aug 14, 2011 | 05:00 PM
socalblueg's Avatar
Default wondering?
would 16x9 +20 would fit eg?
Old Aug 14, 2011 | 05:11 PM
toyomatt84's Avatar
Sanji
Default Re: wondering?
Not without fender flares, unsafe amounts of camber, or unsafe tires (stretched).
Old Aug 15, 2011 | 07:17 PM
socalblueg's Avatar
kinda lookin into the hella flush seen like the esm wheels what offset would be ok? +30? idk if they make them in diff offsets?
Old Aug 16, 2011 | 02:28 AM
92civiceg9gsr's Avatar
A 9" wheel doesnt fit without fab work on the trailing arm, or a retarded amount of camber and low offset. An 8" wheel would be a much better choice for your flushing.
Old Aug 16, 2011 | 05:25 AM
toyomatt84's Avatar
Sanji
If you're looking in to stretching tires to achieve this goal, keep in mind that this is in the Forum Rules and FAQ:
10. Do not ask about "stretching" tires onto wheels that are too wide.
All such topics will be locked. Tire manufacturers determine the wheel widths onto which each model and size tire can be mounted safely, and you can find the range of these wheel widths in the specs on their websites as well as those of retailers like the Tire Rack. Mounting tires onto wheels outside this range of approved wheel widths is unsafe because it can, and often does, result in the buildup of excessive stress and heat in the tire sidewalls, which can lead to the tire "popping the bead" and/or tire failure. Make sure your tires are mounted on wheels whose widths are within the approved range.
Old Aug 16, 2011 | 07:32 AM
socalblueg's Avatar
alright thanks guys!
colbyem2
Apr 21, 2012 10:57 PM
jdmchickx
Jan 5, 2012 03:12 PM
b16vtecguy
Dec 27, 2011 03:21 PM
b0yg0tskills
Feb 16, 2010 06:34 AM
Tarmac Junkie
Nov 19, 2008 03:29 PM
