will this work on my S2K (offset)
Old Sep 19, 2010 | 09:43 PM
wrXtian's Avatar
Default will this work on my S2K (offset)
i found some rims i wanted to buy, but i'm concerned about the offset on the front. would these rims fit, and what kind of tire would you recommend for the rims?
"Selling a set of Rota D2 wheels.
They have a bolt pattern of 5X114.3
They are 18X8 in the front and 18X9 in the rear.
I think the rear's have a +45 offset and the front's have a +35."
for the front i was thinking 205 40 18 to try and keep rubbing to a minimal
the rear i thought 245 45 18
thanks
Old Sep 20, 2010 | 09:52 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: will this work on my S2K (offset)
I don't know about the offset. Hopefully someone else here can answer that part of your question.
You have to be careful finding rims for the S2000, because of the difference in center bore. The S2000 has different size hubs front and rear, and needs wheels which have the matching center bores.
That front size is a little small and the rear size is MUCH too large. The Tire Rack recommends 225/40-18 front (0.8 percent larger outer diameter than the stock 205/55-16) and 255/35-18 rear (0.7 percent larger than the stock 225/50-16).
Old Sep 27, 2010 | 08:39 AM
Jdm_Ego's Avatar
these would look sick !
rhdjeezy
10
Sep 16, 2009 03:40 PM
v8killacivic
Honda S2000
Feb 18, 2008 09:43 AM
JusT a Cx
Honda S2000
25
Jun 12, 2005 11:26 PM
xtremecivichb
Honda S2000
13
Oct 3, 2003 04:04 PM
dut
Honda S2000
16
May 19, 2003 09:25 AM
