Will this size fit?
Old Dec 21, 2006 | 04:42 AM
CiViC_LoVeR_101's Avatar
Default Will this size fit?
I JUST BOUGHT SUM TIREZ 195/60/14 THE GUY SAID THEY WILL FIT ON MY 93 EG COUPE STOCK STANDARDS SAYS ITS 185/60/14 ....WILL I HAVE PROBLEMS LIKE RUBBING OR W.E SORT?
Old Dec 21, 2006 | 07:18 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Will this size fit? (CiViC_LoVeR_101)
They will probably not rub, but they will make your speedometer and odometer read low by 2.1 percent.
I wouldn't buy oversized tires, but if you already bought them - especially if they came on a set of wheels, so they're basically free - then just use them up, and then go back to the proper size tires when you need to buy more.
P.S.
Old Dec 22, 2006 | 06:20 AM
SHPrelude00's Avatar
the O.D. (overall diameter) on a 185/60R14 is 22.80 inches...the O.D. on a 195/60R14 is 23.30 inches... so yea i will fit and you should have any problems except maybe your speedometer being off about 3-5mph... all this is assuming no lowering... you may or maynot have issues after lowering...
Old Dec 22, 2006 | 06:57 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Will this size fit? (SHPrelude00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHPrelude00 &raquo;</TD></TR><TR><TD CLASS="quote">your speedometer being off about 3-5mph...</TD></TR></TABLE>
You mean, at 144-241 miles per hour?
Sounds like you didn't bother reading the previous post, just above yours...
Old Dec 22, 2006 | 10:45 AM
Default Re: Will this size fit? (nsxtasy)
yea...opps thanks nsx
Old Dec 22, 2006 | 01:49 PM
FalkenSiR's Avatar
y0 taht shizzy is tyte f00, st33li3s aRe s!ck wit it s0n
AlecB
26
Oct 9, 2012 11:13 AM
tegda
Jan 26, 2007 10:05 AM
DC2 12
Aug 24, 2006 12:34 PM
DC2 12
Honda Civic (2001 - 2005)
Aug 24, 2006 12:20 PM
hollis
Nov 29, 2004 07:45 PM
