Will it Rub
Old Jun 15, 2005 | 02:26 PM
tequilakid's Avatar
Default Will it Rub
Will 16x7 Rota Sub-Zeros with 205/45-16's rub on my DA which is lowered about 2-3" on non-adjustable coilovers?
Old Jun 15, 2005 | 02:47 PM
Moogen Powah's Avatar
Default Re: Will it Rub (tequilakid)
It doesn't look like you're lowered too much, but whether or not you will rub your tires also depends on the offset of the wheel. So the offset of your Subzero's is?
Old Jun 15, 2005 | 02:51 PM
c_mack9's Avatar
yeah it dont look that low. you could prolly go with 20's if you wanted to.
Old Jun 15, 2005 | 03:17 PM
tequilakid's Avatar
Default Re: (c_mack9)
The offset of the Sub-Zeros +40
Old Jun 15, 2005 | 03:35 PM
Mike_C's Avatar
what coilovers are they? it depends on the spring rates...
Old Jun 17, 2005 | 01:13 PM
Earthworm Jim's Avatar
I'm going to say it will rub but it's a questionable yes.
Old Jun 17, 2005 | 02:39 PM
sooo_slow's Avatar
New User
Default Re: Will it Rub (TheGeneral)
No, it will not rub, i have 16's on my DA, which is lowered 3"...no rubbing at all, and by ur pic, my car is like twice as low as yours, my fronts are tucked a little bit.
Old Jun 17, 2005 | 04:01 PM
inkedup's Avatar
Default Re: Will it Rub (sooo_slow)
My DA is lowered about 3 inches on ground controls sitting on 205/45/16 tires/ Rota grids (same offset as the subzeros)
So far I havent rubbed during normal driving but when Im pulling out of my steep driveway with my front drivers side wheel turned all the way to the right, it rubs slightly... I can deal with it
Old Jun 17, 2005 | 05:26 PM
sooo_slow's Avatar
New User
Default Re: Will it Rub (inkedup)
I thought he meant will the tires rub/fenders.....not will the car rub/scrape...b/c if thats the case then yes..my car does scrape..im also on ground controls.
Old Jun 17, 2005 | 05:35 PM
inkedup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sooo_slow &raquo;</TD></TR><TR><TD CLASS="quote">I thought he meant will the tires rub/fenders.....not will the car rub/scrape...b/c if thats the case then yes..my car does scrape..im also on ground controls.</TD></TR></TABLE>
Yeah, my drivers side tire rubs one of the screw heads that holds down the plastic fender lining... I havent scraped at all but Ive came very close a few times.
Did you go with custom rates for your GC's. I paired them up with Koni Yellows and personally I feel they are too soft. Im looking into buying a pair of Ground Control top hats up front for some extra travel.
Old Jun 17, 2005 | 05:55 PM
solareclipseauto's Avatar
should be fine
Old Jun 18, 2005 | 06:22 AM
EFbomb's Avatar
what kind of coilover doesnt adjust ? wouldnt that just be a spring ?
Old Jun 19, 2005 | 04:39 PM
onesikcivic's Avatar
i dont think there should be a problem, unless you got crappy that make it bounce and then hit the walls
1995Civiccx
Feb 9, 2007 11:50 AM
Jesterian
16
Dec 26, 2006 06:34 AM
GeorgeJetson
Nov 15, 2005 09:44 PM
93egsi
Jun 14, 2003 05:28 PM
