wheels shake @ 65 and above
Old Aug 30, 2008 | 11:04 AM
westsnip's Avatar
(Trial User)
Default wheels shake @ 65 and above
HI i have a 2006 acura rl 14000 miles on it i put new 20 inch wheels and falken tires on them from the get go the wheels shake @ 65 and above to about 80 i have had them balanced 4 times by a 3 of places wheels balance on balancer put them on my car and the shake stock wheels do not shake i have plastic hubcentrc rigs on them also lug nuts get about 4 to 5 full turns on lug wheels fit tight can the rigs be the problem at wits end may toss wheels in river help thanks jim
Old Aug 30, 2008 | 11:42 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: wheels shake @ 65 and above (westsnip)
Since your old wheels/tires don't shake and the new ones do, the problem is definitely with the wheels/tires and not anything on your car.
I can think of several possible problems.
First, 4 or 5 turns on the lug nuts is NOT enough. Some people say 6, and others say 7, but never less than 6. With too few turns, you don't have enough of the lug nuts holding the wheels on. They may be wiggling loose. So that's one possible problem. If you want to use these wheels, you really need to get extended studs, and probably also open-ended lug nuts.
You may also not have torqued them enough; you need to tighten them to 80 ft-lbs on your torque wrench. If you're not using a torque wrench, buy one. You can get inexpensive, decent ones at Harbor Freight.
It's possible that one or more of the wheels are bent, and/or that there is a defect in one or more of the tires. You may be able to isolate which one by rotating them around on the car to see where the shaking is coming from.
It's also possible that you need to learn how to use punctuation to separate your sentences when you type out a paragraph.
Old Sep 3, 2008 | 10:54 AM
UncleD's Avatar
Default Re: wheels shake @ 65 and above (nsxtasy)
Did any of the 4 places have a road-force balancer?
Are you using cone seat or ball seat lug nuts?
Did they static or dynamicly balance the tires/wheels?
Old Sep 3, 2008 | 11:47 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: wheels shake @ 65 and above (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Are you using cone seat or ball seat lug nuts?</TD></TR></TABLE>
Good point. Aftermarket wheels need lug nuts with a conical shaped seat. You shouldn't use your stock lug nuts, which have a ball shaped seat. This could be a big part of the problem (exacerbated by insufficient turns on the lug nuts).
See the FAQ topic stickied at the top of this forum for an illustration.
Old Sep 3, 2008 | 03:25 PM
hybrid90's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by westsnip &raquo;</TD></TR><TR><TD CLASS="quote">HI i have a 2006 acura rl 14000 miles on it i put new 20 inch wheels and falken tires on them from the get go the wheels shake @ 65 and above to about 80 i have had them balanced 4 times by a 3 of places wheels balance on balancer put them on my car and the shake stock wheels do not shake i have plastic hubcentrc rigs on them also lug nuts get about 4 to 5 full turns on lug wheels fit tight can the rigs be the problem at wits end may toss wheels in river help thanks jim</TD></TR></TABLE>
That is the looooongest run-on sentence EVER with no PERIOD at the end! That's just plain CRAAAZY son!
Old Sep 5, 2008 | 01:06 AM
EKsos_57's Avatar
Default Re: wheels shake @ 65 and above (hybrid90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid90 &raquo;</TD></TR><TR><TD CLASS="quote">
That is the looooongest run-on sentence EVER with no PERIOD at the end! That's just plain CRAAAZY son! </TD></TR></TABLE>
lmao, i was just about to say that! I ran out of breath at the end...but hey, can't blame the guy, he sounds really worried, but yea, that one dude talked about the lug nut styles has a good point, so make sure you got the right lug nuts for the application, buuuut there's another point i gotta make since speed is a factor...do you have the correct speed rating on the tires?
this may be helpful 1010tires
Modified by EKsos_57 at 2:15 AM 9/5/2008
Old Sep 5, 2008 | 06:15 AM
UncleD's Avatar
Default Re: wheels shake @ 65 and above (EKsos_57)
Speed rating is not going to affect the ride quality of a tire. Besides, if you're driving your vehicle up to your tire's speed rating, you're breaking all sorts of laws and shouldn't be doing so.(U.S.)
Old Sep 5, 2008 | 01:13 PM
EKsos_57's Avatar
lol...alright, i see, cross that off then....thanks
MasterCrx
May 15, 2006 07:24 PM
